I would like to use my arduino pins to control a 12 V light that has its own power supply. So what I need is something that can be used as a switch (here is in pink color) but I don't know much about electronics so I don't know what part to put there. I don't want to use transistors as they require to use the same ground potential.
    \$\begingroup\$ "I don't want to use transistors as they require to use the same ground potential", and why is this a problem for you? Or is this just a random preference you've acquired? \$\endgroup\$ – Harry Svensson Sep 24 '18 at 10:28
  • \$\begingroup\$ I need the arduino to be on always and the car battery requires a key to let the power trough so conneting it together would break the power at the arduino \$\endgroup\$ – Jumperz Ko Sep 24 '18 at 10:30
    \$\begingroup\$ You can still share the same ground, regardless of if the battery is powering something up or not. If the Arduino is on a separate supply, then it can still be always on, and have the whole circuit share a ground. Use transistors. That's the best way \$\endgroup\$ – MCG Sep 24 '18 at 10:33
  • \$\begingroup\$ so i need to connect the grounds and replace the pink part with a transistor(with resistors) and i'm good to go? \$\endgroup\$ – Jumperz Ko Sep 24 '18 at 10:36
For simplicity and robustness, use a relay. That's basically a electrically-controlled mechanical switch.
You can get modules that contain relays and that are controlled directly from digital outputs. You can also make your own circuit to do that. Driving a relay from a digital signal has been discussed many times here before. Look around.
  • \$\begingroup\$ Whoever downvoted this, what do you think is wrong? \$\endgroup\$ – Olin Lathrop Sep 24 '18 at 15:45
Make ground common and use logic level power mosfet. If you don't want to make ground common then use relay
Option 1: Mosfet
Option 2: Relay
  • \$\begingroup\$ The user is cleary a novice so this answer is not likely to help at all. I didn't downvote but if you add a schematic for both of your solutions I imagine that you may get some upvotes. There is a CircuitLab button on the editor toolbar and it will save editable schematics inline with your post. \$\endgroup\$ – Transistor Sep 24 '18 at 12:24
  • \$\begingroup\$ 100 Ω pull-down on the gate of the NMOS, really? \$\endgroup\$ – Harry Svensson Sep 25 '18 at 11:10
  • \$\begingroup\$ sorry, it should be greater than 1 mega \$\endgroup\$ – Uzair Ali Sep 25 '18 at 19:18
    \$\begingroup\$ A IRF540 is inappropriate for the use in your first schematic. It is only specified for 10 V gate drive. It is not meant to be driven from a digital signal, not even a 5 V one. Also, R1 is barely needed at all. Since the arduino isn't a FET driver, R1 could easily be left off. 10 kOhms is way too high. \$\endgroup\$ – Olin Lathrop Sep 26 '18 at 11:00
  • \$\begingroup\$ If you would've swapped the 100 Ω pull-down with the 10 kΩ then it would've made sense. Keeping the 10 kΩ and replacing 100 Ω with 1 MΩ is really bad. The RC constant (gate capacitance and your resistors) will be unnecessarily large. - To be crystal clear, your 10 kΩ should be ~100 Ω and your 1 MΩ should be ~10 kΩ. \$\endgroup\$ – Harry Svensson Sep 28 '18 at 11:55
