When using the original Power Brick the Smartphone came with to charge it, does a 3rd-Party cable cause any harm to the device or is there no difference to using the original cable?
closed as off-topic by Elliot Alderson, Michel Keijzers, brhans, Finbarr, Leon Heller Sep 24 '18 at 12:58
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Elliot Alderson, Michel Keijzers, brhans, Finbarr, Leon Heller
If this question can be reworded to fit the rules in the help center, please edit the question.
Typical connector theory applies.
In order for a smartphone cable to function it needs the following properties:
  • Proper connector within spec, otherwise it has bad contact or will damage the socket.
  • Enough copper wire to handle the current. Otherwise voltage drop will cause charging to abort. This is especially a problem since USB cables were not intended to do >500 mA, until smartphones came around.
  • In case of iPhones: A valid ID chip. Otherwise the iPhone will say: "Accessory incompatible".
Damage will only occur when there is a physical problem with the cable, or a polarity problem of course, but those are rare.
Most damage will happen when the cable or socket has wear. After many mating cycles, cheap cable contacts wear out causing higher resistance, with more heat. Sometimes the phone melt and causes fire.
This is because the springiness of the contacts degrades over time, and degrades faster when heated. When you often use a slightly off-spec cable, it might cause damage in the long run.
Don't be stingy on a 10$ cable for your hundreds of dollars device.
  • \$\begingroup\$ For the last line alone plus one ! \$\endgroup\$ – Solar Mike Sep 24 '18 at 12:23
  • \$\begingroup\$ I'm not trying to be stingy or safe some money. I'm actually intending buying a cable with higher quality from a good 3rd-Party. But since I have no idea of such things, I was worried about damaging my phone. \$\endgroup\$ – Suimon Sep 24 '18 at 12:34
