in the verilog code below:
module mem_try(
     clk,
     addr,
     data_in,
     rd,
     wr,
     data_out
      parameter addr_length=32,data_width=32,ram_depth= 1 << addr_length;
      input [data_width-1:0]data_in;
      input clk,rd,wr;
      input [addr_length-1:0]addr;
      output reg [data_width-1:0]data_out;
      reg[data_width-1:0]ram[ram_depth-1:0];//ram variable decalaration
      assign write_only =wr&~rd ;
      assign read_only =~wr&rd ;
      always@(posedge clk) begin
      if(write_only) begin
         ram[addr]<=data_in;
      end
      if(read_only) begin
        data_out<=ram[addr];
      end
      end
endmodule
After synthesis I get the following error:
[Synth 8-3331] design mem_try has unconnected port addr[31](30 more like this)
and a distribute ram is formed.
Can anyone point out the mistake and how a bram can be inferred?
    \$\begingroup\$ please indent all of the code by 4 more spaces so that it shows up as code .... you can also select the code text and click {} button \$\endgroup\$ – jsotola Sep 26 '18 at 5:12
  • \$\begingroup\$ I'm not sure if this is the cause of the error, but it is usual to have the number of bytes in a ram specified as [0:size-1] but you have this reversed. \$\endgroup\$ – Jules Sep 26 '18 at 11:01
    \$\begingroup\$ @Jules you can specify it either way. What's more interesting is the attempt to make a 16GB array in in distributed RAM. \$\endgroup\$ – Tom Carpenter Sep 26 '18 at 17:58
  • \$\begingroup\$ any suggestions how can i infer a block ram ? what changes do i need to do . If i chnage the addr_length and data_width to 8 ,(0.50)BRAM is inferred . \$\endgroup\$ – Shubham Choudhary Sep 27 '18 at 4:58
Looks like you should be able to infer a block RAM with that. Not sure if that read /write exclusive logic will trip anything up. I wuld recommend setting the address width much smaller, maybe something between 8 and 16, otherwise the synthesizer is not going to be happy.
