I have this 433MHz RF Tx and Rx pair. I tried to transmit using following simple Arduino sketch, given in the VirtualWire manual.
#include <VirtualWire.h>
void setup()
vw_setup(2000); // Bits per sec
void loop()
const char *msg = "hello";
vw_send((uint8_t *)msg, strlen(msg));
delay(400);
I've installed VirtualWire Library
properly (it's there in Sketch -> import Library
). But Arduino IDE gives following errors when trying to verify. It says 'vw_setup' was not declared in this scope
In file included from sketch_sep08a.cpp:1:
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:59: error: variable or field 'vw_set_tx_pin' declared void
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:59: error: 'uint8_t' was not declared in this scope
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:63: error: variable or field 'vw_set_rx_pin' declared void
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:63: error: 'uint8_t' was not declared in this scope
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:67: error: variable or field 'vw_set_ptt_pin' declared void
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:67: error: 'uint8_t' was not declared in this scope
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:71: error: variable or field 'vw_set_ptt_inverted' declared void
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:71: error: 'uint8_t' was not declared in this scope
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:76: error: variable or field 'vw_setup' declared void
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:76: error: 'uint16_t' was not declared in this scope
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:90: error: 'uint8_t' does not name a type
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:98: error: 'uint8_t' does not name a type
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:104: error: 'uint8_t' does not name a type
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:107: error: 'uint8_t' does not name a type
C:\Users\LordXaX\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:112: error: 'uint8_t' does not name a type
sketch_sep08a.cpp: In function 'void setup()':
sketch_sep08a:3: error: 'vw_setup' was not declared in this scope
sketch_sep08a.cpp: In function 'void loop()':
sketch_sep08a:9: error: 'vw_send' was not declared in this scope
Why is that. How to fix this?
This is the content of imported VirtualWire.h
// VirtualWire.h
// Virtual Wire implementation for Arduino
// See the README file in this directory fdor documentation
// Author: Mike McCauley ([email protected])
// Copyright (C) 2008 Mike McCauley
// $Id: VirtualWire.h,v 1.3 2009/03/30 00:07:24 mikem Exp $
#ifndef VirtualWire_h
#define VirtualWire_h
#include <stdlib.h>
#include <wiring.h>
// These defs cause trouble on some versions of Arduino
#undef abs
#undef double
#undef round
// Maximum number of bytes in a message, counting the byte count and FCS
#define VW_MAX_MESSAGE_LEN 30
// The maximum payload length
#define VW_MAX_PAYLOAD VW_MAX_MESSAGE_LEN-3
// The size of the receiver ramp. Ramp wraps modulu this number
#define VW_RX_RAMP_LEN 160
// Number of samples per bit
#define VW_RX_SAMPLES_PER_BIT 8
// Ramp adjustment parameters
// Standard is if a transition occurs before VW_RAMP_TRANSITION (80) in the ramp,
// the ramp is retarded by adding VW_RAMP_INC_RETARD (11)
// else by adding VW_RAMP_INC_ADVANCE (29)
// If there is no transition it is adjusted by VW_RAMP_INC (20)
#define VW_RAMP_INC (VW_RX_RAMP_LEN/VW_RX_SAMPLES_PER_BIT)
#define VW_RAMP_TRANSITION VW_RX_RAMP_LEN/2
#define VW_RAMP_ADJUST 9
#define VW_RAMP_INC_RETARD (VW_RAMP_INC-VW_RAMP_ADJUST)
#define VW_RAMP_INC_ADVANCE (VW_RAMP_INC+VW_RAMP_ADJUST)
// Outgoing message bits grouped as 6-bit words
// 36 alternating 1/0 bits, followed by 12 bits of start symbol
// Followed immediately by the 4-6 bit encoded byte count,
// message buffer and 2 byte FCS
// Each byte from the byte count on is translated into 2x6-bit words
// Caution, each symbol is transmitted LSBit first,
// but each byte is transmitted high nybble first
#define VW_HEADER_LEN 8
// Cant really do this as a real C++ class, since we need to have
// an ISR
extern "C"
// Set the digital IO pin to be for transmit data
// Defaults to 12
extern void vw_set_tx_pin(uint8_t pin);
// Set the digital IO pin to be for receive data
// Defaults to 11
extern void vw_set_rx_pin(uint8_t pin);
// Set the digital IO pin to enable the transmitter (press to talk)
// Defaults to 10
extern void vw_set_ptt_pin(uint8_t pin);
// By default the PTT pin goes high when the transmitter is enabled.
// This flag forces it low when the transmitter is enabled.
extern void vw_set_ptt_inverted(uint8_t inverted);
// Initialise the VirtualWire software, to operate at speed bits per second
// Call this one in your setup() after any vw_set_* calls
// Must call vw_rx_start() before you will get any messages
extern void vw_setup(uint16_t speed);
// Start the Phase Locked Loop listening to the receiver
// Must do this before you can receive any messages
// When a message is available (good checksum or not), vw_have_message();
// will return true.
extern void vw_rx_start();
// Stop the Phase Locked Loop listening to the receiver
// No messages will be received until vw_rx_start() is called again
// Saves interrupt processing cycles
extern void vw_rx_stop();
// Return true if the transmitter is active
extern uint8_t vx_tx_active();
// Block until the transmitter is idle
extern void vw_wait_tx();
// Block until a message is available
extern void vw_wait_rx();
// or for a max time
extern uint8_t vw_wait_rx_max(unsigned long milliseconds);
// Send a message with the given length. Returns almost immediately,
// and message will be sent at the right timing by interrupts
// Returns true if the message was accepted for transmissions
// Returns false if the message is too long (>VW_MAX_MESSAGE_LEN - 3)
extern uint8_t vw_send(uint8_t* buf, uint8_t len);
// Returns true if an unread message is available
extern uint8_t vw_have_message();
// If a message is available (good checksum or not), copies
// up to *len octets to buf.
// Returns true if there was a message and the checksum was good
extern uint8_t vw_get_message(uint8_t* buf, uint8_t* len);
#endif
VirtualWire.h
content. Thanks! \$\endgroup\$
