This is probably a marginal mistake.
This circuit, a current regulator:
Works fine on simulation.
However, it does not once built. I built it twice, once on a PCB once on a breadboard, using different components, and both behave the same.
The OA2 output is either at High or Low, depending on the V1 but is not regulating anything.
I also observe some kind of schmitt trigger behavior, current is 0 and V1 is 0, then slowly increase the voltage, it suddenly switch to the max output. Then I have to reduce V1 to almost 0 to stop conducting.
There is no oscillation or anything like this. it's either fully on / off instead of regulating.
At this point I do not believe it's a mistake on the build.
