I'm using a SIM800L GSM module for my project. In this module there is a electret mic input pin but I want to give audio to this module from headphone output from a mobile (There is no line in pin available). If I directly input from headphone out the module make too much noise. Now what is the best idea to implement this?
Here is module instruction diagram:
SIM800L mic integration
Mic input/Audio output characteristics
  • \$\begingroup\$ Welcome to EE.SE. Not sure what you are asking of us. To use a speaker as a microphone? Using a speaker as a mic will overload the mic input. The mic input may have a small bias voltage as well. \$\endgroup\$
    – user105652
    Sep 28 '18 at 19:57
    \$\begingroup\$ See electronics.stackexchange.com/questions/239708/… Not a dupe but likely does solve it. \$\endgroup\$
    – Passerby
    Sep 28 '18 at 21:49
  • \$\begingroup\$ Decrease the volume on the source and turn it up on the target device. This sounds like it could just be typical behaviour. \$\endgroup\$
    – K H
    Sep 29 '18 at 7:50
I just did this, so I can answer by experience. I have a SIM800L module that's answering calls via a PHP script on a Raspberry Pi 3, and I wanted to send PicoTTS voice on the line using the AUX jack audio output. I followed this youtube tutorial using "mostly" the correct values components. I got the resistances pretty much right by playing with 4.7k and 1k resistors, and just the capacitor is shooting up with 47uF instead of 1uF.
I only connected the left side of the jack output leaving the other lead unconnected, the level I get on the phone is alright, the voice quality is alright, I just get some vibrating noise as soon as the phonecall is connected, which disappears slowly and after a while of mostly clean audio comes back, as if a big fly was briefly flying by and then going away again. But still, I can testify it works, an the noise is OK with me anyway.
Line level converter
The 90mW into 32 ohms from the headphones output of your mobile is 1.7V (RMS?). The output of your voice from an electret mic (conversation level at a distance of 10cm) is only 10mV. So you must attenuate the headphones signal 1.7V/10mV= to 1/170.
90mW into 32 ohm headphones is VERY loud. 100mV from an electret mic is also VERY loud. Then attenuate to 1.7V/100mV= 1/17th.
    \$\begingroup\$ This would be a lot more useful as an answer if you explained how to do that. If the asker knew how to design an attenuator they probably would not have asked the question. \$\endgroup\$ Sep 29 '18 at 4:38
