I'm running transient simulations as I am sweeping a couple of parameter values (resistances, capacitances) to give a first hint about what range of values make a certain circuit stable. In addition, I want to extract certain measurements from the wave form, in order to basically give me a figure of merit for the given parameter combination. These measurements limit how short time period I can use for the simulation (as in, it turns out I can't go below about 200µs if I want the measurements from that run).
Each run takes a fairly long time, so I would like to avoid, if possible, running the whole transient simulation if I can already see that these particular values causes oscillations.
Is there any way to tell LTSpice that "no, this parameter combination is dead in the water, skip this and continue with the next"?
