I want to calculate the current labeled in the diagram \$i\$. I am thinking that since there is 3V it would be as straightforward as \$\frac{3V}{6\Omega}\$ for the current in that branch labeled. Is that the correct thinking or am I missing some concept? I see that there is 2A being delivered as well, but would that change my answer?
schematic diagram
You need to use superposition to solve this circuit.
Superposition means solve for the current i due to the voltage source, with the current source set to 0A (i.e. current source disconnected). Then, find the current i due to the current source, with the voltage source set to 0V (i.e. voltage source shorted). Then, add the two together to get the final answer. Good luck!
  • \$\begingroup\$ Thanks! Also, if i was to do this using the nodal method, would I consider the entire 3V wire in the first section to be a single node? \$\endgroup\$ – Jytrex Sep 28 '18 at 21:55
  • \$\begingroup\$ What do you mean by "the entire 3V wire in the first section"? \$\endgroup\$ – Selvek Sep 28 '18 at 22:03
  • \$\begingroup\$ top left corner to the intersection where i is. \$\endgroup\$ – Jytrex Sep 28 '18 at 22:05
  • \$\begingroup\$ When calculating the effects of the current source, you replace the voltage source with a short. So yes, that would be a single node. \$\endgroup\$ – Selvek Sep 28 '18 at 22:16
