What is the usage of the EEPROM in embedded application? can you give me examples?
5\$\begingroup\$ What is the usage of long-term memory in your brain? Can you give me examples? \$\endgroup\$ – Harry Svensson Sep 29 '18 at 8:43
2\$\begingroup\$ Is this homework? \$\endgroup\$ – Transistor Sep 29 '18 at 8:44
1\$\begingroup\$ i am just trying to clarify the subject in my mind. And this is not my homework. I am studying on a book about microcontrollers and microprocessors, i read about memory devices, rom prom eprom eeprom. and i am wondering, these are not much memory blocks. what is the usage what can we do with them? is it a problem that i am asking about it? \$\endgroup\$ – emincetin Sep 29 '18 at 8:47
\$\begingroup\$ Look at the (consumer) products around you, like TV, (car) radio, thermostat, (alarm) clock, keyfob, etc. Would you be happy if removng power/batteries restored them to their production (or pre-configuration!) state? \$\endgroup\$ – Wouter van Ooijen Sep 29 '18 at 8:49
1\$\begingroup\$ EEPROMs (or devices like them) perform important duties in CPU-based devices. As said before, a basic Internet search should yield plenty of explanations. Compare EEPROM with PROM, ROM, UV-EPROM and Flash memories. If you have a specific question, please ask it. \$\endgroup\$ – mike65535 Sep 29 '18 at 9:56
As noted in the comments my answer to EEPROM is a Read Only Memory so why can I write to it? provides some relevant information.
Table 1. Summary of memory type features.
WRITEABLE ERASABLE RETENTIVE Notes
RAM Yes Yes No Data loss on power cycle.
ROM At factory No Yes Data designed in.
PROM Yes No Yes Data user programmable.
EPROM Yes With UV Yes Wipe contents with UV light.
EEPROM Yes Yes Yes Change data while running.
The main benefit of EEPROM is that it is writeable like RAM (but much more slowly) but unlike RAM the data will survive a power cycle. It's typically used to store configuration settings or data that should survive a power cycle. Examples include devices such as a printer where parameters such as IP address, paper size, etc. and data such as total page count need to be restored on power-up.
