I'm wanting to create a wind powered LED similar to this one, but weather proof. I know there's tons of them out there, but I'm wanting to build it from scratch. My issue is that I'm completely novice when it comes to electronics, and I don't even know what to search for.
For example, when I search "fan that produces electricity", I mostly get hits for fan motors, or huge wind turbines. Is there a specific name for fans that produce electricity?
This type of device is called a turbine, and the word turbine can also describe just the blade arrangement that converts fluid pressure into rotational motion. A set of stationary blades that rotate a fluid(air or water) are called a spinner and the moving blades of a water turbine are generally called the runner.
Currently there are not a tremendous number of small cheap turbines on the market due to limited demand. There are startups for a backpack wind turbine, wind/water turbine and water turbine going right now and that's about it if you want a purpose built product. If you want your own, you can repurpose a fan with a permanent magnet DC motor, but that would be hard to waterproof. If you want something small, you could look at brushless RC motors, and look for the lowest kV rating you can find. The lower the kV rating, the more power you can generate at the same RPM.
As far as waterproofing, having the blades separate from the motor allows you to either seal the motor shaft or use a magnetic linkage for waterproofing. If you go with a blade design that will result in extreme torque shifts from wind gusts, a magnetic linkage makes a nice shock absorber and can offer you the most absolute form of weatherproofing, but I would suggest for the moment discarding the idea of making it waterproof and just finding any fan you can start playing around with(it just needs the right type of brushless motor in it).
The joule thief circuit shown in your video is simple and cheap to build. The parts he shows are a transistor, a transformer(shared core inductor) and a resistor, so if you search each of those things and "joule thief" you should learn everything you need. The joule thief with an LED is a good beginner circuit because it is automatically switching efficient(the transistor tends to be hard on or hard off so switching losses are negligible) and it lets you ignore the input voltage requirements of the LED. You may also need to look up each other word you don't understand as you find them.
The one other thing shown is a high power LED on a MCPCB, and if you acquire yourself one of these, due to the built-on heatsink, they are extra tough in terms of the power level you can feed them. Because it's hard to put an absolute limit on what a turbine might generate without knowing a tremendous amount of university level math or doing extensive testing, you're much less likely to fry one of these due to a gust of wind. IIRC the joule thief just uses whatever power you feed into it based on the resistor you choose, so it's great for getting an LED to turn on even if the source voltage is lower than the LED voltage, but if you really get a wind turbine going (try putting a windsock on a small fan) a high power LED will handle the surge better than a low power one.
A wind turbine is the technical name for a purposely built generator in a fan shape that produces electricity from kinetic motion of wind pushing on it.
As mentioned, many fan motors can be used as a wind turbine, by the very nature of their construction. Any basic motor that does not have driving circuitry embedded on it can be used as a generator.
The Passerby answer is valid, although I think the goal was to find the parts for what is on the video.
You probably won't find anything of this sort by searching wind turbine.
You can just use:
  • a DC motor (with permanent magnet).
  • a diode.
  • filtering capacitor.
  • resistor and LED in serie.
    and this should make your circuit work.
  • \$\begingroup\$ Using a phrase such as "the previous answer" makes no sense on this site as answers move up and down by votes or user's sorting preferences. Why is a bridge rectifier and capacitor required when using a DC generator? \$\endgroup\$
    – Transistor
    Sep 30 '18 at 8:10
  • \$\begingroup\$ A simple diode is fine indeed \$\endgroup\$
    – Damien
    Sep 30 '18 at 8:19
    \$\begingroup\$ And why do you need a diode and capacitor? The only reason for the diode would be if the turbine could run backwards somehow. The output of a DC generator is smooth already so the capacitor isn't required either. \$\endgroup\$
    – Transistor
    Sep 30 '18 at 8:25
  • \$\begingroup\$ So that when the motor stops or slow down the led stills light for a little while \$\endgroup\$
    – Damien
    Sep 30 '18 at 9:59
  • \$\begingroup\$ OK, but did you do a quick calculation to see how long it would last? The time constant is given by RC so multiply 1µ x 330 and see how many seconds the LED will stay lit for. What do you get? \$\endgroup\$
    – Transistor
    Sep 30 '18 at 12:43
