I'm trying to run an old Bitcoin miner project in Vivado. The old code is written in Verilog and the rest of my project is in System Verilog.
I have a syntax error I don't know how to solve. It basically boggles down to a single line (that you can see in the full source code here)
data15_p1 <= `S1( S[i-1].data[`IDX(15)] );
Expanding the macro manually and cleaning it up to replicate the error, I get:
data15_pl <= ( { S[i-1].data[511:480][16:7] } );
Here is what I understand is happening: the IDX macro takes a 32 bit subset from the 512 bits s[].data. [16:7] is then used to try and take bits 16 to 7 of those 32, but Vivado complains with the "Range is not allowed in a prefix" error.
Do I need to rewrite the code using a temporary wire variables to get this to work?
Edit: I think not because I can't use a wire in that scope? Using a register would add delays. Maybe the only option is manually expanding and changing all of the defines?
Changing the file extension from .v to .sv got me past the syntax error and on to synthesis errors that I cannot fix (part select out of range of prefix), as some people in old Xilinx thread, which makes me think I need to rewrite this.
