I have make an STM32F030F4P6 board for reading analog values. When I connect the analog pin to vcc the value is 4095, instead when I connect the analog pin to GND the value isn't 0. How can I solve the problem?
The schematic project:
    \$\begingroup\$ "the value isn't 0" - ok - so what is it? \$\endgroup\$
    – brhans
    Oct 2 '18 at 15:25
  • \$\begingroup\$ the value is between 100 and 300 \$\endgroup\$ Oct 2 '18 at 16:02
  • \$\begingroup\$ Is the system you're integrating this into one where you can "zero" it when it initializes? \$\endgroup\$ Oct 2 '18 at 17:50
  • \$\begingroup\$ I don't know ! I use a STM32F030F4P6 mcu as in the schematic project. \$\endgroup\$ Oct 2 '18 at 18:20
  • \$\begingroup\$ You need to read the data sheet for the device and pay particular attention to the ADC part. Maybe you should cut and paste the section table for the ADC. \$\endgroup\$
    Oct 2 '18 at 18:24
You should check out chapter 12.4.1 of the Reference Manual. The STM32 can calibrate its own ADC perhipal! Offset error is a common problem for internal ADCs in microcontrollers I've encountered so far.
The calibration can be done by the following steps:
  1. Ensure that ADEN=0 and DMAEN=0
  2. Set ADCAL=1
  3. Wait until ADCAL=0
  4. The calibration factor can be read from bits 6:0 of ADC_DR
This can be a problem of your layout. Maybe the ground is not routed ideally and you have a slight voltage difference in your system.
Have you measured the voltage difference between the controller ground and your analog pin pulled to ground?
