For a certain TI component, I'm choosing between these two packages, both of which are 24-pad and 0.5mm pitch:
  1. QFN: http://www.ti.com/lit/ml/mpqf167b/mpqf167b.pdf (4 x 4 mm)
  2. BGA: http://www.ti.com/lit/ml/mpbg520/mpbg520.pdf (3 x 3 mm)
Some considerations:
  • BGA is cheaper for a PCBA house to assemble, correct?
  • If I use 3 mil microvias (on a 6-8 layer board) to route out BGA components, how many rows/cols does a 0.5mm BGA have to be before the routing gets annoying?
Any advice appreciated!
    \$\begingroup\$ AFAIK, there's no significant cost benefit to using BGAs over QFN's. I think the tradeoff is that the BGA is roughly 1/2 the area; whereas the QFN can definitely be routed without microvias. If you don't already need microvias for some other part in your design, adding them to support this part might increase your blank board cost by 50%. \$\endgroup\$
    – The Photon
    Sep 10, 2012 at 1:02
    \$\begingroup\$ On the other hand, are you sure you need microvias to route the BGA? The first two rows should be routeable without vias under 4/4 design rules. And the center ball has an escape at location b2, so you should be able to route that with a through via. \$\endgroup\$
    – The Photon
    Sep 10, 2012 at 1:05
  • \$\begingroup\$ Already need microvias. \$\endgroup\$ Sep 10, 2012 at 1:05
    \$\begingroup\$ on the clearances to the neighbor components, usually the limitation for these types of parts is to allow for rework without removing other parts. I doubt if there's any reason for different clearance between BGAs and QFNs since both need a hot air system for rework. ... but again, you might get a different answer if other regulars here get a chance to respond. \$\endgroup\$
    – The Photon
    Sep 10, 2012 at 1:18
    \$\begingroup\$ 4 mil minimum copper feature size, 4 mil minimum separation between copper features. Nowadays a pretty common design rule that won't add much to your costs. \$\endgroup\$
    – The Photon
    Sep 10, 2012 at 1:48
Why do you think the BGA is cheaper in assembly? The operation is the same for both: pick and place. But the BGA needs X-ray for inspection, and the assembly shop may charge extra for that. The QFN can be visually inspected.
The QFN also lets you reach the pins with a probe. For a scope probe no problem, but for a DMM you'll need needle probes.
If you can afford the extra couple of square mm the QFN needs I would go for that. After all you can still use via-in-pad to save space.
bga mechanical drawing
