Why does LVDS (or any differential signaling for that matter) use a common mode voltage of 1.2V instead of 0V?
Is there an easy way to shift the common mode voltage to 0V?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhy does LVDS (or any differential signaling for that matter) use a common mode voltage of 1.2V instead of 0V?
Because, then the signal would have to be negative also. The trick is to use a positive single power supply. Now the differential signal is centered arround 1.2V and the applied differential signal is +/-175mV.
Using a 0v common mode, the signal would be +/-175mV meaning that you need dual power supply - negative and positive at both sides, which is more expensive.
