I have a simple circuit comprised of seven 5V relays and eight 5mm LEDs, if the supply is 5V, it will draw a max of 660mA DC.
I was planning to use a 7805 positive voltage regulator rated for 1A, so at worst conditions, it will be working at 66% of it's max current rating.
Is this an acceptable percentage considering that the circuit will be mounted inside a metal chassis so I can bolt the regulator to it to heat sink and ground the circuit?
I usually de-rate all my parts to about twice the currents and voltages they will ever see so 66% seems reasonable but I've read how tricky current ratings are because of proper heat sinking and temperature rise factors.
Is 66% still safe or should I look at one of those high-current circuits using a transistor that appear on datasheets, or look for a 1.5A regulator?
Thanks in advance for any input!
  • \$\begingroup\$ 7805 is short-circuit protected, so any current is "safe" but if it over-heats your circuit will malfunction. \$\endgroup\$
    – Jasen
    Oct 4 '18 at 4:38
6
The maximum current of a regulator is only one limiting factor. Another, usually more restrictive, limitation, is the total power dissipation. With a linear regulator like the 7805, the power dissipated by the regulator will be equal to the difference between the input voltage and the output voltage multiplied by the output current. So if your regulator is providing 5V@660mA from a 9V supply, the regulator is dissipating (9-5)*0.660 = 2.64W. If you have a regulator in a TO220 package attached to a heatsink, that could be okay, but without a heatsink the regulator will likely get too hot.
To check, you would need to look up the relevant thermal resistance of the package and multiply this by the dissipated power. This will give you an estimate of the difference between the internal temperature of the regulator's die and either the ambient temperature or the temperature of the heatsink tab, if your regulator has such a tab. Add that temperature to the ambient or heatsink temperature, and compare this to the maximum rated die temperature of the IC. Note that since the die temperature will depend on the ambient temperature, you may find that the die temperature will exceed ratings in some conditions, but not others. So it's important to know the environmental conditions in which your system will operate.
Also note that when a heatsink is involved, its thermal resistance will come into play as well. If you know the approximate thermal resistance of your heatsink in your expected operating conditions, then you can add the heatsink's thermal resistance to the regulator package's thermal resistance, and obtain a total thermal resistance between the die and the ambient air. However, the performance of a heatsink is highly dependent on airflow conditions, so in some cases the heatsink's characteristics must be measured in situ (or carefully simulated) for accurate results.
