I want to calculate the temperature coefficient for a digital multimeter. The datasheet I read it is calculated as:
0.1*(specified accuracy)/°C (<18°C or >28°C)
Do you know what specified accuracy stands for?
I mean, can I consider specified accuracy as the composition of multimeter accuracy and resolution?
Thank you in advance.
    \$\begingroup\$ I wouldn't think that it "stands for" anything. It's the accuracy, as specified in the meter's handbook. \$\endgroup\$ – Simon B Oct 4 '18 at 14:13
  • \$\begingroup\$ I think that the accuracy is specified by calibration report of the instrument. \$\endgroup\$ – Railectric Oct 4 '18 at 14:50
According to Full scale Accuracy:
Accuracy of a multimeter is given as a function of specified accuracy .
Accuracy = (specified accuracy / 100 ) * FSD.
FSD refers to full scale deflection which is the largest value can the multimeter measures.
  • \$\begingroup\$ Thank you for the answer. Can you quote the source of this explanation please? \$\endgroup\$ – Railectric Oct 5 '18 at 20:04
  • \$\begingroup\$ Electronic Instrumentation and Measurements, 2nd Edition David Bell . \$\endgroup\$ – Romyo Oct 6 '18 at 8:59
  • \$\begingroup\$ Specified accuracy related to analog multimeter \$\endgroup\$ – Romyo Oct 6 '18 at 9:00
