14
I volunteer at the Dauphin Railway Museum in Manitoba, where we recently received a donation of equipment collected by CNCP Telecommunications in the 1970s and earlier.
Most has been identified, including testing equipment, telegraph relays, Telex terminals and a medical coil (!) but one piece has stumped everyone who's looked at it. It is a cylinder about 17cm diameter, wood at either end with a number of thick metal plates through it. On the upper surface there are a couple of connections for wire. The five hard metal posts on the top seem to be the heads of bolts to hold the whole thing together. A.E. Morrison (a former manufacturer of electric milk floats in the UK) is stamped into the top surface. I have not attempted to open it up as I suspect it would tell me nothing.
Top view
Underside
  • \$\begingroup\$ @GregoryKornblum I'm not quite sure if your comment is productive or not, but it has certainly made my day! Richard, are these bolts isolated from the brass contacts? What do you see when you remove the brass curved plate? (the elongated screw holes in that brass plate definitely look like it was meant to be easily removed) \$\endgroup\$ – Marcus Müller Oct 7 '18 at 17:54
    \$\begingroup\$ The brass cover on the side is designed to be easily removed and put back on. What is behind it? \$\endgroup\$ – JRE Oct 7 '18 at 18:38
    \$\begingroup\$ Less blurry, better pictures could help. As well as measuring continuity everywhere. Opening my tell you nothing, but someone else maybe more. Any moving parts? Not good for ee.se but a high Res video might work best \$\endgroup\$ – PlasmaHH Oct 7 '18 at 18:43
    \$\begingroup\$ it may be a part of a chart recorder for keeping a record of engine speed .... are the disks magnetic? \$\endgroup\$ – jsotola Oct 7 '18 at 20:33
    \$\begingroup\$ I'm voting to close this question as off-topic because it has been abandoned by an asker who has not returned to the site since the day after posting, leaving clarification questions unanswered. \$\endgroup\$ – Chris Stratton Jan 4 at 16:46
It is hard to tell the relationship of the circle cutout and the 2 adjustment screws, but Telegraph was popular and this looks like an arc suppression instrument that passes the high voltage used for telegraphy. Hence it has 2 screw adjustments for the centre conductor but it seems to me that it ought to arc near the inside of the circle cutout on the outer brass plate for a breakdown rating of about ~3kV/mm gap.
It would be something like a spark gap lightning arrestor used on powerline poles. The metal plates are added for mass and stabilizing the desktop unit. A.E. MORRISON and sons were prominent inventors and supplier of electrical equipment in the U.K.
Anecdotal
I remember as a kid for 4 years growing up on Kirby St, in Dauphin, Mb in the mid-'60s with my pickle jar radio and wire across the street, I could listen to Saskabush radio at night, get the "hummadidity" weather report when I should have been sleeping and listen to CKY in Winnipeg. My Dad never knew about the risk of an outdoor wire antenna to the tree across the street from stray lighting pickup on the antenna, but I wouldn't discover that till I did Seismic research for UofM during the summer of '73 on boat with 100m of cable going to an island... I loved my time in Dauphin with the schools, outdoor hockey, the Park Cafe and the Ukrainian Festival.
Regarding trains and the EMI radiated from the traction motors, it wasn't until 1982 I tested CATV coax lines one day in River Heights, Winnipeg that got interference from poor coax shielding from poor distributed earth-grounding that caused interference on the low band cable TV channels. MTS owned all the TV distribution cables and twisted pair phone lines at that time and we did Project IDA for them. Trains emit a lot of EMI up to 100MHz! at that time. This was a residential back lane that was 100m or so from the train tracks.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
