I've seen power protection that uses:
  • MOV (metal-oxide varistor)
  • Inductor
  • TVS diode
Application Note: Transient Voltage Suppressors (TVS Diode) Applications Overview
enter image description here I didn't see any design guide for the inductor selection I choose 1 A inductor 4.7 µH, but doesn't that mean it will carry the surge current that TVS should clamp?
I'm not sure is 4.7 µH the right selection or not.
  • \$\begingroup\$ I do not see any reason for placing an inductor between the protective elements. If used, it should be placed after the TVS diode so that the diode can do it’s job. \$\endgroup\$ – Stefan Wyss Oct 8 '18 at 19:30
  • \$\begingroup\$ the first picture is not mine, as much as i understand, the inductor is there to delay surge current from TVS diode so the varistor takes most of the power of that surge. i dont know if its effective or not that what comes in my mind \$\endgroup\$ – Hasan alattar Oct 9 '18 at 5:53
  • \$\begingroup\$ Why don’t you simulate it? \$\endgroup\$ – winny Oct 9 '18 at 6:11
  • \$\begingroup\$ i've never used simulation, only the one altium provide for very simple circuits RC, LC, filters that already have spice model by default. \$\endgroup\$ – Hasan alattar Oct 9 '18 at 6:52
  • \$\begingroup\$ i did use LT spice today, it just doesnt give what i should do, good to see that 8kV voltage gets shunted by the varistor and zener diode but it need much more study of spice simulation i guess to simulate the real component and i guess current and voltage should be measured \$\endgroup\$ – Hasan alattar Oct 9 '18 at 8:54
