For the wire type in Verilog, I know that I can define a multiplexer as follows
wire a;
assign a = select ? 1'b0 : 1'b1;
And for reg's, I can do it as follows
reg a;
always @ (select)
begin
    case(select)
    1'b0: a = 1'b0;
    1'b1: a = 1'b1;
    endcase
end
Now my question arises - it's so easy to describe complex multiplexers using regs/always blocks/procedural statements. It seems so tedious to do the same with wires. What if I wanted to describe a very complex multiplexer driving a wire? Would my select? line be huge?
    \$\begingroup\$ AlfoJang, you should be declaring your variables as reg or wire depending how you assign to them, not choosing how to assign to them based on how they are declared. \$\endgroup\$ – The Photon Oct 8 '18 at 17:03
Just use the case and declare the signal as a reg. The distinction between wire and reg in Verilog is rather artificial anyway -- there's really no functional difference between them, just some (mostly historical) syntax rules.
You can do
assign a = somefunction(select);
function somefunction(input sel);
begin
  case(sel)
  1'b0: a = 1'b0;
  1'b1: a = 1'b1;
  endcase
end
endfunction
The only complication is every input to your block of logic has to be an input your function.
Using the variable form, you can use @* and not worry about it.
