I've been looking to build a universal charger for my laptop and phone, and I'm wondering; is there a viable way to adjust the input voltage to match the battery's ideal charging voltage by measuring A and B across an arbitrary load?
The scenario is as follows;
0) I've got a universal charger that can output anywhere from 5V to 24V
1) I want to charge my phone, so I plug it into the universal charger
2) Without my interaction, the circuit and it's microcontroller adjusts itself to the required voltage (5V)
3) I now unplug my phone and plug my laptop in for charging
4) Without my interaction, the circuit and it's microcontroller adjusts itself to the required voltage (24V)
How can I measure the required voltage without checking the battery label?
  • \$\begingroup\$ you either have interaction or you don't ... you cannot have both .... you need to rethink what you are trying to do .....measuring A and B across an arbitrary load is interaction \$\endgroup\$ – jsotola Oct 9 '18 at 6:56
The problem with your scheme is that the battery isn't directly connected to the charging socket. There will be a charging controller in between:
So from the charging port it is not possible to determine what voltage is needed to charge the device.
Only if there is communication between the power adapter and the Charging controller can your scheme work. Qualcomm Quickcharge is an example of that. If the charge controller does not support such a protocol then what you propose cannot be done.
Think about it: USB ports that are designed for 5 V can usually handle 6 V - 6.5 V at most, applying 24 V to such a port will for sure damage it severely.
|improve this answer|||||
  • \$\begingroup\$ I see - so basically I would have to figure out a way to interface with each proprietary charging controller in order to get it to tell me what voltage it needs. \$\endgroup\$ – ARMATAV Oct 9 '18 at 23:03
  • \$\begingroup\$ I would have to figure out a way to ...tell me what voltage it needs Sure, but most charge controllers don't support this function so in practice you cannot get this interfacing to work. The charge controllers simply aren't designed for this. \$\endgroup\$ – Bimpelrekkie Oct 10 '18 at 6:22
