I am confused about when to use KVL/KCL or ohm's law to solve the circuit question?
I need to compute voltage in point B and point C, every current pass through R1 R2 R3 R4
R1= 100 ohm, R2=300 ohm, R3=250 ohm, R4=500 ohm
V1= 5V, Is=20mA
I tried to use ohm's law to find all current first, but I don't know how to use Is to help me. Or find out the total resistance then finding total current?
And how to use Is when applying KCL, is it a current source?
Or I can separate circuit into two independent circuits to solve the question.
I hope someone can help me to clear my electricity concept.
the resistance of r1 and r2 =1/(1/100+1/250)= 500/7 ohm ≈ 71.4 ohm
total resistance of a circuit = 500/7 + 300 + 500 = 6100/7 ohm ≈ 871 ohm
current supply from 5V : I = V/R = 5/(6100/7) = 7/1220 A ≈ 5.74mA
I1=5.73 mA
I1=I2+I3
5.73= (VB-VGround)/250 + (VB-VC)/300 = VB/250 + (VB-VC)/300
5.73=VB/250 + (VB-VC)/300 -(1)
I4+Is = (VC-VGround)/500
I4+ 20mA = VC/500 -(2)
apply KVL: VB-(VB-VC)+VC = 0 -(3)
Is it correct, should I continue?
  • \$\begingroup\$ I mean, no offense, I see you are a new user, but I cannot see any effort from you, at least attempting to solve the problem. \$\endgroup\$ Commented Oct 10, 2018 at 12:59
  • \$\begingroup\$ You say that you have tried to use Ohm's law etc. If you show what work you have done, and the steps you have taken, then we can help you figure out when and how you got confused and help you get back on the right track \$\endgroup\$
    – MCG
    Commented Oct 10, 2018 at 13:06
  • \$\begingroup\$ I apologize for my lazy and naive, I will show my step. \$\endgroup\$ Commented Oct 10, 2018 at 15:51
When in doubt simplify: -
And if you don't understand what I've done look up Thevenin's and Norton's theorums about replacing current sources with voltage sources and vice versa.
  • \$\begingroup\$ Good start for the user. \$\endgroup\$
    – mike65535
    Commented Oct 10, 2018 at 14:48
  • \$\begingroup\$ But how does 6V come out? Why can you add a voltage source between R2 and R3? \$\endgroup\$ Commented Oct 10, 2018 at 16:21
    \$\begingroup\$ A 20 mA current source in parallel with 300 ohms is identical to a 6 volt source in series with 300 ohms. Both have the same short circuit current (20 mA) and open circuit voltage (6 volts). \$\endgroup\$
    Commented Oct 10, 2018 at 16:24
  • \$\begingroup\$ Ok, so how do you know the current supplied from 5V? You don't need to calculate the total resistance first? By V=IR \$\endgroup\$ Commented Oct 10, 2018 at 16:38
    \$\begingroup\$ The 5 volt source is exclusively in series with 100 ohm therefore it is equivalent to a 50 mA current source in parallel with 100 ohms. Wikipedia has a very good page on the theorems I mentioned. \$\endgroup\$
    Commented Oct 10, 2018 at 18:18
