I have the following combinatorial assignment in a verilog module:
assign ififo_di = fetching_pc ? { 5'h02, 3'h7, 16'h8000 } : decoded_insn;
where ififo_di
is an output, fetching_pc
is a local register and decoded_insn
is an input (which, in all my testing so far, is always set to 24'h000000).
And have a clock-triggered action that sets fetching_pc
for a single cycle in specific circumstances. The same block also provides synchronous reset and sets up a monitor for debugging purposes:
always @(posedge clk)
begin
fetching_pc <= !reset & next_task_ready;
if (reset)
begin
// reset registers
$display ("ifetch reset");
$monitor ("active: %b, task_loaded: %b, fetching_pc: %b, ififo_di: %b", active, task_loaded, fetching_pc, ififo_di);
active <= 0;
task_loaded <= 0;
end
end
The test bench code that triggers these actions is:
@(posedge clk);
reset = 1;
@(posedge clk);
reset = 0;
@(posedge clk) #10;
next_task_channel = 3;
next_task_thread = 0;
next_task_ready = 1;
@(posedge clk) #10;
// at this point the ififo_di output is checked and the test fails
At the time the next_task_ready
input is set to 1, the reset
input is 0, and the internal registers active
and task_loaded
are both verified as containing 0 (although task_loaded
is changed to 1 in the same cycle -- but altering this so that this change doesn't take place gives identical results).
My expectation is that when this happens, ififo_di
will change from 000000h to 178000h, however what really happens (testing in icarus verilog) is this:
ifetch reset
active: 0, task_loaded: 0, fetching_pc: 0, ififo_di: 000000000000000000000000
ifetch reset
active: 0, task_loaded: 0, fetching_pc: 1, ififo_di: 000x0xxxx000000000000000
Why would the output by changing the bits that need to change to x
rather than to 1 as expected? I would understand if fetching_pc
were x
, but it's clearly being shown in the monitor output as 1, so what's going on here?
(updated: Eliminated some unnecessary code so that I can provide the entire always
block as tested, thus showing all potentially-relevant content of the module.)
\$\endgroup\$task_loaded
to 1, which causesfetching_pc
to return to 0, but I have also tested without this change and the issue persisted. \$\endgroup\$
