I have a refrigerator that stopped working. A few years ago the board was burnt near a relay contact therefore I looked at the board as the primary culprit. I am trying to test the relays to determine if these are broken but have no experience with this and the information I got was not very helpful. For the relay 832A-1C-S I tested the resistance (the two bottom pins) and I got 153.8 ohms. Does this mean (according to specs; link below) that this relay is not working? For the 812H-1A-S I am not sure if there is anything I can test with a multimeter. Any help will be appreciated.
The datasheets for these relays are: https://www.mouser.com/datasheet/2/378/832a-257239.pdf http://www.songchuan.com/db/pictures/AdminModules/PDT/PDT090410001/201191914401494858.pdf
Relays
  • \$\begingroup\$ The zig-zag line indicates a coil. Honestly it is most always the contacts that wear out, and is a common problem with relays with a high usage rate. Rather than fuss with them just search the web or the manufactures site for replacements. These are sealed in epoxy, so no DIY fix. \$\endgroup\$
    – user105652
    Oct 11, 2018 at 2:28
From the datasheet, the coil resistance is supposed to be about 155\$\small\Omega\$, then your relay from this information seems not to be damaged though it doesn´t mean it´s or not. The coil may be good but there can be a failure with the mechanical contacts.
So to make sure it´s working or not, power it with a 12\$\small Vdc\$ voltage source and try to light up a led or to deliver power to any other load.
One way to test the relay is to apply and remove the stated voltage across the coil (12 VDC for those shown) and check continuity across the contacts with a multimeter set to Ohms or to Continuity (which beeps, so you don't have to watch the meter).
The voltage source could be a 9-volt battery, which might be sufficient for relay pull-in, but if that doesn't work, use a 12-volt power supply or even car battery (with care: don't short-circuit a car battery!).
When current is supplied, the normally open (NO) contacts should close and normally closed (NC) contacts should open.
