I am trying to design the following schematics:
There are two kOhms resistance which are connected serially. One is load and another is device resistance. I need to apply the voltage in a the following way using IC switch
  • When voltage on the IC switch is non zero the voltage is applied only on the device
  • When it is zero the both R_load and R_device connected serially
Schematics
Since the signal through the resistance is a pulse with duration less than 100 ns I am using a couple of op-Amps for impedance matching (the measurements are carrying out on 1 MOhm oscilloscope channel). So I have to use fast IC switch.
For the first experiment I used constant voltage (~500 mV) applied on both resistance. I see the oscillations at the moment when switch is on or off. How can I remove these oscilltaions? I tried these schematics without op-Amps, and saw the same behaviour.
I tried on the several switches
  • ADG712
  • SN74LVC1G3157
  • SN74LVC1G66
  • \$\begingroup\$ Show how you measure, that is, with a gnd antenna or properly low inductance \$\endgroup\$ – PlasmaHH Oct 11 '18 at 12:02
  • \$\begingroup\$ Sorry, I didn't get your question. I simply connected PCB to the oscilloscope, generator and power supply with coaxial cables and soldered wires respectively. \$\endgroup\$ – anatoly Oct 11 '18 at 12:40
  • \$\begingroup\$ Do these glitches also occur at the output of the buffer amplifier? You're switching its load, so it needs to react to that; unless it's very carefully compensated, you'd expect to see some sort of transient there. \$\endgroup\$ – Dave Tweed Oct 11 '18 at 12:45
  • \$\begingroup\$ I also tried these schematics without op-Amps, and saw the same behaviour. \$\endgroup\$ – anatoly Oct 11 '18 at 12:46
  • \$\begingroup\$ Do you have a 50-ohm termination on your oscilloscope? Many oscilloscopes have a switchable 50 ohm input mode. Otherwise you can use a feed through terminator. \$\endgroup\$ – τεκ Oct 11 '18 at 14:09
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
