Based on my understanding of VHDL, a port map statement looks like:
signal reset_n : std_logic;
port map (
    reset_n => reset_n
... where the LHS of the port map assignment is the port name on your component and the RHS is a signal you've declared above.
But for a generic map, what does the RHS refer to?
generic map (
    baud_rate => baud_rate
The LHS is the generic field in the entity to be written to by whatever the RHS specifies (right?), the VHDL way of passing a value into your generic. But if the RHS is not declared as a signal (which it is not, based on test benches I've looked at), what is being assigned/wired to the LHS? What is going on under the hood?
closed as off-topic by Dave Tweed Oct 11 at 17:32
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • RHS is the value to be assigned to the LHS. As simple as that. If it is not defined in your design, then it has a bug. hdlworks.com/hdl_corner/vhdl_ref/VHDLContents/GenericMap.htm – Eugene Sh. Oct 11 at 16:03
  • Where would that value be assigned? If you simply have baud_rate => baud_rate in your generic map, is the RHS the value assigned in the generic(...) in your component above? – schadjo Oct 11 at 16:05
    The baud_rate on the left is not the same baud_rate on the right. LHS is the generic name, RHS is the expression to be assigned, and in your case baud_rate has to be defined somewhere outside the generic block – Eugene Sh. Oct 11 at 16:08
  • -1 You posted the same question on two forums near simultaneous. That is against the rules , impolite and very much frowned upon. – Oldfart Oct 11 at 17:16
  • It's a stupid rule. – schadjo Oct 11 at 17:17
