I want to buy some replacement batteries and the best priced ones come with bare wires. I would therefore need to attach my own connector to the end.
What is the name if this type of connector and how can I go about identifying this one specifically (which parts do I measure)? I will also need the metal clips that attach to the wires. What are those called and what kind if tool would I need to attach them?
  • \$\begingroup\$ That type of battery is often supplied with some form of connector from JST, which might help you find it. \$\endgroup\$
    – Hearth
    Oct 12, 2018 at 0:22
  • \$\begingroup\$ Unless you're doing a lot of these, your best bet might be to spend extra money for the pre-installed connectors. The crimping tools can be expensive. See here for general information on how to crimp/assemble similar connectors. \$\endgroup\$
    – bitsmack
    Oct 12, 2018 at 7:14
This is a 1mm pitch micro JST "SH" connector (part number SHR-02V-S-B) and is available from DigiKey.
SH is the name of a specific series of connectors by JST Sales America, Inc.
    \$\begingroup\$ SH stands for Super Hard to disconnect without breaking them. \$\endgroup\$
    – Passerby
    Oct 12, 2018 at 14:07
    \$\begingroup\$ @Passerby So true! I often use a tiny flat-bladed screwdriver to work these out to avoid ripping the wires from the terminals. \$\endgroup\$ Oct 12, 2018 at 15:12
  • \$\begingroup\$ I couldn't fit even my smallest precision flat head in there to free the cable. I ended up having to use an x-acto knife to get in there and pull away locking mechanism. I wonder if there is an easier way. \$\endgroup\$
    – Zhro
    Oct 12, 2018 at 16:13
