I searching for a way to do high side current sensing on a -1100V DC rail.
My HV is generated from the hamamatsu C9619 High voltage power supply module and it powers the hamamatsu R647P Photomultiplier tube together with the E849-90 D-type socket assembly also from hamamatsu.
My current region is up to 500 μA.
Any ideas or suggestions would be extremely helpful.
If your need is only for occasional measurements, it would be easy enough to create a battery-powered wireless milliammeter. For example a shunt resistor, op amp and a microcontroller with some kind of wireless communication (eg. WiFi or Bluetooth).
Another approach would be to make a current sink circuit using a high voltage MOSFET that operates at the -1100V rail. The Hamamatsu C9619 is capable of 2mA current so you have a fair bit to play with. You would have to use (continuous) high voltage rated resistors for the power dropper (and, to be prudent, in series with the high-voltage N-channel transistor drain). A very low power op-amp and a very low Iq shunt regulator for the power would complete the circuit. Recieving it would be a transimpedance amplifier referenced to ground. Pick the series drain resistor to limit the current to a few mA.
For example:
You could use a hall effect current sensor. 500uA isn't much, but you can use multiple passes through the loop to get a large enough reading.
Another option would be to use an isolated current shunt. You can either do this with a dedicated device, or simply use a microcontroller, and then pass the signal through an opto-coupler. You'll need an isolated power supply for the microcontroller; or you could just run it on a battery.
  • \$\begingroup\$ Why the downvote? \$\endgroup\$
    – Drew
    Oct 12, 2018 at 18:01
  • \$\begingroup\$ i don't know , i send it to zero by upvoting \$\endgroup\$
    – Chris Sy
    Oct 22, 2018 at 6:53
I have 3 solutions for you:
1 - Replace the power source with one that has both voltage and current meters.
2 - Buy a clamp-on DC uampmeter. Make sure you use it in "floating" mode.
3 - Design and build your own DC uampmeter.
