I know LED stands for Light Emitting Diode; but why does this component need to be a diode to emit light?
My question assumes that the "leds" we see everywhere (for lighting, screens, etc) are actually diodes -- this assumption might be wrong.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThe existing answers miss the core of the question.
An LED needs to be a diode, specifically because the way the charge carriers recombine in the forward-biased diode junction releases the correct amount of energy to create photons in the visible range. Passing a current through a chunk of semiconductor with no diode junction in it would simply produce heat.
It's also important for efficiency that the semiconductor be a direct band gap material, so that energy is not lost to phonons (crystal vibrations — heat) rather than photons.
Regular silicon diodes emit light, too, but because the band gap is too low, the photons emitted are in the infrared range, and invisible to the eye. Also, silicon is an indirect band gap material, which greatly reduces its efficiency at producing photons at all.
By conservation of energy, light emission implies power input. It is normal to deliver electrical power through two wires, so the simplest electric powered light emitter has two wiring terminals, i.e. is a diode.
Two-terminal semiconductors replaced two-terminal tubes (vacuum or gas-filled) having two electrodes, which were called 'diode', and the name has stuck. Electroluminescent panels of yesteryear were also semiconductors that gave off light, but weren't produced in the kinds of high-tech assembly lines that electronic diodes are made in. So, those weren't called diodes.
White "LED" devices around you are not simple semiconductor diodes, but are structures with diodes and phosphors that give off useful amounts of white light, having a blue-emitting diode and red/orange/yellow/green phosphors that convert the blue light. Lenses and other features for effective light emission are common; LEDs do not resemble other practical diodes, except that they have two wires or connecting terminals.
- that makes zero sense otherwise capacitors, resistors and coils should also be called diodes
Oct 15, 2018 at 2:57
Because LEDs are a diode which posses the same characteristics a common solid state diode.
Your assumption is correct.
A diode is an electronic component that has low resistance in one direction. It is a dual electrode (anode and cathode) device where electron flow from cathode to anode is low conductance and the primary electron flow is the high conductance flow from anode to cathode.
The most common diodes are made of crystallized semiconductor materials (e.g. silicone, germanium and gallium arsenide, indium phosphide, sapphire, and quartz) which are doped with p and n type impurities which are separated by the simplest semiconductor building block, the p-n junction.
There are many types of diodes with various characteristics. It is the properties of the p and n dopants and their affect on the voltage-current characteristics of the p-n junction that separates one type of diode from another.
The above applies to all diodes including LEDs.
In LEDs the dopants have electroluminescence properties. When the electrons are crossing the p-n junction, many of the electrons are transformed into sub-atomic particles called photons.
Light Emitting Diodes are called diodes because the are indeed semiconductor diodes that also emit photons in the form of UV, visible light, and IR.
A diode is the simplest semiconductor device. And, the simplest semiconductor device can also be made to emit light. Voila! Light emitting diode! One could potentially call it a light emitting semiconductor device(LES), but that would just sound like a real name... sooo not cool.
[edited] From the comments below, semiconductor devices without diodes exist. However, they seem to be sensors and do not emit light. The peltier module does transfer heat, but does not create it. So, it is conceivable that a light emitting semiconductor device may be created in future which is not a diode. However, it would likely have a new name (not a diode or LED).
So, thus far, in a TV screen and everywhere else, if it is called an LED, the light (visible or invisible part of the spectrum) actually originates from the LED itself. It is the cheapest efficient light source to produce. There can off course be "fake LED"... neon bulbs or mini incandescent bulbs that look like LED. I have seen those in christmas light decorations, and they are a bit cheaper than the real thing.
i know that birds lay eggs, but do they really have to lay eggs?
... maybe ask about thelight emission from a PN junction
instead of asking if"what we know as LED" has to be a diode
... bottom line, it was discovered that a PN junction emits light, and has desirable properties while emitting light ... that discovery has been developed to the level that we see today ... it has to be a diode (PN jnc) \$\endgroup\$
