-1
i am looking to build a simple transmitter that will transmit on 433mhz automatically every 20ms or less. would this even be possible to make?
the transmitter only needs to be simple and set off a very short range buzzer attached to a simple receiver. the device will have to use 433mhz and run from battery power.
closed as unclear what you're asking by RoyC, Dave Tweed Oct 13 '18 at 20:34
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ I don't see any reason it wouldn't be possible. \$\endgroup\$ – Hearth Oct 12 '18 at 22:17
  • \$\begingroup\$ what components would you recommend? \$\endgroup\$ – Mick Oct 12 '18 at 22:37
    \$\begingroup\$ I dunno. What do you need to transmit? What's your budget? You need a lot more details before we'll be able to help. \$\endgroup\$ – Hearth Oct 12 '18 at 22:41
  • \$\begingroup\$ sorry im not the most technically minded. but ive updated the question \$\endgroup\$ – Mick Oct 12 '18 at 23:01
  • \$\begingroup\$ Ain't that what basically the garage door keys do - bursting a byte of info? \$\endgroup\$ – sx107 Oct 12 '18 at 23:20
No, you can't. Besides, why do you need to update the status of a buzzer every 20 ms1 anyway?
The FCC puts strict limits on the duty cycle of "automatic transmissions", including the fact that the period cannot be less than 10 seconds under any conditions.
There's a good summary of the rules in this TI application note: ISM-Band and Short Range Device Regulatory Compliance Overview
1 Hmm. If you're trying to transmit something like Morse Code, I'm afraid you'll have to find a more efficient encoding scheme.
