I forgot to turn off the power of system before I did some continuity test using a multimeter.
Basically an +-V dual supply was powering a transducer. Transducer was outputting very small offset like 100mV and had almost 8k output impedance so I'm not worried about that much.
But I also did continuity test between V+ and V-; V+ and GND; V- and GND ect.
When I each time heard continuity sound I noticed that I forgot to turn off the power. So I turned off and did the same test.
But many hours later I was afraid if I did damage the power supply.
What happens if nodes +15V and -15V or + for instance is checked with continuity of a multimeter when the power is on? I know that would be short if it were a wire but is there possibility power supply is not damaged?
  • \$\begingroup\$ I'd expect that the meter, rather than the power supplies, would be damaged, if any damage ocurred. \$\endgroup\$ – Peter Bennett Oct 13 '18 at 1:15
  • \$\begingroup\$ Your power supply is probably fine. Your meter might not be, though; make sure it still works. \$\endgroup\$ – Hearth Oct 13 '18 at 1:39
  • \$\begingroup\$ Can anyone explain how the power supply is protected? I thought continuity test is just a diode:/ \$\endgroup\$ – panic attack Oct 13 '18 at 1:44
  • \$\begingroup\$ Power supplies are often (and lab power supplies almost always) designed to withstand some pretty bad conditions. What a multimeter does to check continuity is the same thing it does to measure resistance, apply a voltage and measure the current, and if the current is sufficiently high it will beep/light up the screen/whatever else it does to signal a positive continuity test. \$\endgroup\$ – Hearth Oct 13 '18 at 2:00
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
