I'm having some problems at my new girlfriend's house. There was a extension cord that was giving shock and I changed to another. This one wasn't giving shock, but when I test it with that screwdriver that lights up a light on electricity, it lights up when touching the plastic part of the wire. The outside I mean. And it is happening with all the extension cords of the house.
What I want to know is if it is normal to the outside part of the wire to conduct correct or if maybe there is a problem with the house electrical system.
English is not my primary language, sorry for any mistakes.
Edit: on the others extensions of the house the light is on although it is very dim
    \$\begingroup\$ that is not normal or safe... sounds like a possible missing neutral somewhere \$\endgroup\$
    – JonRB
    Oct 13 '18 at 1:32
  • \$\begingroup\$ You should get an electrician to look at the house. I'm not sure what could be causing that, but it sounds dangerous. \$\endgroup\$
    – Hearth
    Oct 13 '18 at 1:32
    \$\begingroup\$ Please show a picture of the cords and tester in question. Is the "screwdriver that lights up a light on electricity" a non-contact voltage tester? \$\endgroup\$
    – K H
    Oct 13 '18 at 1:33
  • \$\begingroup\$ dropbox.com/s/vb35cxv7npuq4xi/IMG_20181012_223645.jpg?dl=0 I think it is. \$\endgroup\$ Oct 13 '18 at 1:41
  • \$\begingroup\$ need more info, where does the shock happen? this isn't a male-male cable, is it? is the shock in the middle, by the connection, or maybe at the end? \$\endgroup\$
    – tuskiomi
    Oct 13 '18 at 1:45
If you get an electric shock when touching the plug of the extension lead then it is likely that the plug and/or the wiring inside is at fault. From the pictures you showed, I would suggest removing the old plug and replacing it with a good-quality new plug, also cutting back the wire to start in a new place.
A neon mains tester such as you showed in another picture works by you being a capacitor (this is normal, nothing to worry about). There is an explanation at How does the tester screwdriver work?
I notice that the extension cord is only two wires. A safer version would have two wires with another insulator over them, like this:
(Image from the CPC website)
However, what I recommend is to buy a new extension lead with a moulded-on plug and socket. This accomplishes two things: it will be safe, and it shows you care.
If that “light-up” tester you are using is one to detect the PRESENCE of electricity without a physical connection to the wire then it is working correctly.
If that tester is one that requires a physical connection then there is an issue that has to be corrected - perhaps moisture on the surface could be the culprit...
