I am welding two plates using TIG machine welding. Before start welding I adjust the current value (i.e. 200 A) and voltage is 20 V. But, the real values of current and voltage will be changed when pass through the plates because of temperature changes. So, how can I measure the real values of current and voltage verses time to get the graphs? I need the full setup of that.
I hope my question is clear.
Thank you
  • \$\begingroup\$ What kind of bandwidth (i.e., time resolution) do you need? What do you hope to do with the data once you have it? \$\endgroup\$ – Dave Tweed Oct 13 '18 at 13:11
  • \$\begingroup\$ Time resolution is Volt/Ampere per second. I need it in my study . \$\endgroup\$ – Husam Oct 14 '18 at 10:30
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
