I am new to VHDL and implementing a test bench. I am trying to write code for a simple 2:1 MUX where the output of the MUX enters an active high synchronous LOAD register. Inputs and outputs are 8 bits. When I run my simulation my output F reads 'U'. I also tried to initialize the output signal in the test bench to (others => '0') but that just makes my output F = 0. Any help would be greatly appreciated, thank you!
DESIGN
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity REG_A is
Port ( A : in STD_LOGIC_VECTOR (7 downto 0);
B : in STD_LOGIC_VECTOR (7 downto 0);
SEL : in STD_LOGIC;
LDA : in STD_LOGIC;
CLK : in STD_LOGIC;
F : out STD_LOGIC_VECTOR (7 downto 0));
end REG_A;
architecture Behavioral of REG_A is
signal s : std_logic;
signal s_mux_result : std_logic_vector(7 downto 0);
begin
regA : process (CLK)
begin
if (rising_edge(CLK)) then
if (LDA = '1') then
F <= s_mux_result;
end if;
end if;
end process;
with s select
s_mux_result <= A when '1',
B when '0',
(others => '0') when others;
end Behavioral;
TEST BENCH
library IEEE;
entity regA_tb is
end regA_tb;
architecture Behavioral of regA_tb is
--INPUTS
signal A : std_logic_vector(7 downto 0) := "01100101";
signal B : std_logic_vector(7 downto 0) := "11100111";
signal LA,SEL : std_logic;
signal CLK : std_logic := '0';
--OUTPUT
signal F : std_logic_vector(7 downto 0):= (others => '0');
component regA
port(
A,B: in std_logic_vector(7 downto 0);
LA,SEL : in std_logic;
CLK : in std_logic := '0';
F : out std_logic_vector(7 downto 0)
end component;
begin
dut: regA port map( A => A, B => B, LA => LA, SEL => SEL, CLK => CLK, F => F);
--GENERATE CLOCK
generate_clock : process
begin
wait for 50 ns;
CLK <= '1';
wait for 50 ns;
CLK <= '0';
end process;
switch_process : process
begin
SEL <= '0';
LA <= '1';
wait for 100 ns;
SEL <= '1';
LA <= '1';
wait for 100 ns;
end process;
end Behavioral;
LDA
, but in your testbench you call itLA
. This disconnect would explain what you're seeing. \$\endgroup\$ – Dave Tweed Oct 13 '18 at 18:14
