I'm trying to do those following the operations on PINS, but not sure how to do the not operation on a port, do xor ..etc? would someone show me an excrept psesuod code ?enter image description here
  • \$\begingroup\$ Imagine that you have functions called or and xor and and and etc. that takes two 8 bits registers and saves the result in one of the 8 bit registers according to the boolean function used. - Do you think you'd be able to solve your assembly-code problem with this information? Or can you at least try solving it on your own? \$\endgroup\$ – Harry Svensson Oct 14 '18 at 16:26
  • \$\begingroup\$ Yes, but what would be the two registers, PORTA, PORTB ? What are the instructions for NOT in assembly ? \$\endgroup\$ – andre ahmed Oct 14 '18 at 16:33
    \$\begingroup\$ That would be one's complement, a.k.a. com. Start looking into some datasheets, particularly page 281 that I just linked. \$\endgroup\$ – Harry Svensson Oct 14 '18 at 16:38
After looking through this I've understood enough to show how \$\text{LED}_0\$ and \$\text{LED}_1\$ can be made, which should show enough for you to implement the other two.
As you can see, \$\text{LED}_0\$ depends on three bits, the easiest solution would be to use temporary registers while you are manipulating the data from \$\text{PA}\$ and then set \$\text{LED}_0\$ once you're done.
Here's one solution for the first two bits, it's not efficient/optimized, but it will make you understand what I'm doing. I will write PA = Port A since that's what you've written in the comments to your question.
MOV TRA,PA // Copy contents from Port A into a Temporary Register A
MOV TRB,PA // Copy contents from Port A into a Temporary Register B
MOV TRC,PA // Copy contents from Port A into a Temporary Register C
LSR TRA //Move all bits once to the right in TRA, so bit1 in TRA is now in bit0
LSR TRB
LSR TRB //Move all bits twice to the right in TRB, so bit2 in TRB is now in bit0
LSR TRC
LSR TRC //Move all bits three times to the right in TRC,
LSR TRC //so bit3 in TRC is now in bit0
AND TRA,TRB //AND TRA and TRB together, bit by bit and save the result in TRA
OR TRA, TRC //OR the new TRA with TRC and store the information in TRA
ANDI TRA,1 //AND TRA with 0b00000001, in other words, remove the mess in other bits
MOV LED,TRA //copy TRA into your LED register
//Now, you're ready for the second bit for your LED register
//As you can see, It's PA1, PA2 and PA3 again, PA2 is still in TRB and
//PA3 is still in TRC, PA1 is demolished, so we need to update TRA again
COM TRB //Make TRB into NOT TRB
OR TRA,TRB //OR TRA with the inverted TRB
AND TRA,TRC //AND the new TRA with TRC
LSL TRA //Move all bits in TRA one bit to the left
OR LED,TRA //Move whatever information is in bit1 in TRA into LED at bit1
//Now you're ready for the other two bits
This should definitely get you started.
Remember that you probably want PA to be PIN_A, PIN_A usually corresponds in assembler language to the input of PORT_A.
If you want to optimize the code, then never move things into TRB and TRC and make TRA move around, it should lead to more efficient code, and use multiplication by \$2^n\$ to copy data into the multiplication register and rotate by \$n\$ to the left.
So just rotate cleverly with the multiplication and look at the high byte of the multiplication register and you will have your rotated information there.
| improve this answer | |
