-1
I have chinese factory that I need to assemble PCB. They cannot open eagle gerber files, only altium how to fix
    \$\begingroup\$ We do not know how you export your files, or anything else. Add more description, otherwise it is nearly impossible to answer. With an old ProtomatS62 I have had that I have to export gerber files in "Legacy" mode. But I doubt that it will help you. \$\endgroup\$ – Atizs Oct 15 '18 at 6:32
  • \$\begingroup\$ This worked! Can you answer so I can accept. \$\endgroup\$ – AceSammy Oct 15 '18 at 12:34
  • \$\begingroup\$ Just to be clear exporting via legacy is what worked \$\endgroup\$ – AceSammy Oct 15 '18 at 12:38
They collect source files. Gerber and Excellon files are enough for PCB production, if factory asks for "source code" without sound explanation it is wise to change the factory.
