I built this power supply for my Schoeps CMT30F vintage microphones:
It works, but it's not the best I can expect in terms of SNR.
What would do you to ensure the SNR is the best possible?
  1. Use 0,1% tolerance 680 Ohm resistors instead of the 1% resistors I used?
    Would this 0,1% one (here in 1k, but I'll find a 680 one) improve something?
1bis. Use 0,1% tolerance 10k resistors as well (right part of schematics)?
  1. Match two 680 Ohm resistors by buying many of them, so that they have exactly same value?
    Could this be useful since it's balanced audio signal with interference reduction? As the output of "2" and "3" are in phase opposition (180°), when subtracting them, we get the signal only and noise cancellates. To have this, is it important that the 2 resistors have exactly the same value?
  2. Buy many 100 µF capacitors and find a pair that matches ESR and capacitance?
    Sidenote: I looked on Farnell, but I couldn't find a "matched pair of capacitors". Do retailers sell "matched pairs" of such capacitors? (could be useful for audio)
  3. Change the capacitor type to use? I used electrolytic caps 100 µF, 50V
  4. Use a more complex schematics? (I saw other microphone phantom power supply schematics on internet with many many components, Zener diodes, etc.!)
  5. Something else?
  • \$\begingroup\$ What exactly do you mean in your context by SNR and how did you come to the conclusion that its not up to your standards? \$\endgroup\$ – PlasmaHH Oct 15 '18 at 8:34
  • \$\begingroup\$ How did you measure SNR? Do you mean noise picked up from the cable? \$\endgroup\$ – pipe Oct 15 '18 at 8:35
  • \$\begingroup\$ Signal to Noise ratio should be the highest possible? ie signal high, noise low... \$\endgroup\$ – Solar Mike Oct 15 '18 at 9:01
  • \$\begingroup\$ Stil doesn't explain how you came to the conclusion that its not good enough and that this is the part of your setup to make it better. \$\endgroup\$ – PlasmaHH Oct 15 '18 at 9:24
  • \$\begingroup\$ Are you sure that your microphone is ok? You say it is vintage so it could degrade. \$\endgroup\$ – Rokta Oct 15 '18 at 11:12
I have done many tests during a few weeks, in order to compare the SNR of a few microphones. Here is the SNR measurement protocol I used.
To do this, I bought some components:
  • 1% 680 Ohm resistors
  • 0,1% more expensive resistors: 536, 665 (680 were out of stock), 715, 1k
  • Vishay 100uF capacitors, and other cheap 100uF capacitors
  • Kemet 10uF capacitors, and other cheap 10uF capacitors
  • Floureon SPL meter
Here are my conclusions:
  • 12V battery vs 9V battery powering: doesn't significantly change the SNR
  • 680 vs 715 vs 1000 Ohm: idem (maybe using the 1000 Ohm gave a (very) little bit less high-frequency noise, but the difference is maybe < 1 dB)
  • 680 1% vs 665 0,1%: idem (because the two 680 1% were already close enough! Both were measured at a value of 678.8...)
  • replace the output 10k resistors by 3.9k ones: idem
  • Kemet vs noname 10uF capacitors: idem
  • Vishay vs noname 100uF capacitors: idem
  • 10uF vs 100uF capacitors: it changes a little bit the cutoff of the highpass filter: when using a 100uF capacitor we keep a little bit more low-frequency signal around 10-100 Hz. It is not significant when measuring the "A-weighted SNR" because these frequencies are pre-weighted by -60dB or -70dB before computing the SNR, but it is a (very) little-bit hearable when comparing both.
Conclusion: The good old Schoeps CMT30F microphones seem to have a "Signal-to-noise ratio, A-weighted (re. 94 dB SPL)" of ~ 70 dBA.
As a comparison I measured 76 dBA for a more recent microphone (Rode NT5, the technical specs says: "Signal/Noise: 78dB SPL (@ 1kHz, rel 1Pa per IEC651)").
|improve this answer|||||
