Last week I was looking for a programmable gain amplifier (PGA) with high gains (> 100V/V) and low noise. As far as I know most of the PGA integrated circuits out there are just (inverting) amplifier stages with the option to digitally switch feedback resistors. Please take a look at the block diagram of the LTC6912 for example:
In my opinion one of the problems you'll face when trying to minimize noise in a high gain standard (inverting) amplifier configuration, is the size of the feedback resitor. The high gain forces the resistor to get big, which results into a lot of noise.
So I started looking for other configurations where the feedback resistor doesn't have to be this big.
I found a very interesting article: https://www.electronicdesign.com/analog/digitally-programmable-amplifier-meets-sensor-gain-ranging-needs
In this article a PGA is built upon a sort of inverting amplifier configuration with a voltage divider in the feedback loop. Because I can't find anymore information about his type of circuit I started analyzing it myself and found the gain formula as follows:
Gain=Vout/Vin
The simulation result below shows the circuit with a large gain of 65.7dB with feedback resistors of only 39k. This seems very useful to me, however I've never seen it before...
When I started reading further, I found that the author used the same opamp configuration as a band pass filter, shown in the picture below.
Because I'm very excited about this topology I'm trying to find formulas for the cut-off frequencies of this circuit. However I really don't know how to do it. Is there anyone who can help me out? More information about these circuits is welcome as well! Thanks
  • \$\begingroup\$ This configuration is good if you want big gain but low noise. You can find a good explanation about T-network here at pag.47 (chapter 3.6), or in the always useful Horowitz-Hill. \$\endgroup\$
    – Antonio
    Oct 15, 2018 at 12:29
To find the lower cutoff frequency and passband gain, you can use Miller's theorem to separate the \$100nF\$ into two capacitances to ground.
The schematic contains a simulation that shows you the similarity.
I determined \$A_{DC} \approx -16\ 443\$, resulting in an input capacitance of \$C_{in} = C\cdot (1-A_{DC}) \approx 1.6mF\$ and an output capacitance of \$C_{out} = C\cdot \left(1 - \frac{1}{A_{DC}}\right) \approx 100nF\$.
Doing so will allow you to calculate the lower cutoff frequency and passband gain.
$$A_{in\to B,miller} = \frac{R_8C_6s}{1+R_8(C_6+C_9)s}$$
There is a zero at f=0Hz, and a first cutoff frequency at
$$f_{p1} = \frac{1}{2\pi R_8(C_6+C_9)} \approx 0.1Hz$$
The passband gain is severely reduced by the capacitive divider circuit.
$$A_{pb} = A_{DC}\cdot\frac{C_6}{C_6+C_9} \approx 5.75 = 15.2dB$$
At high frequencies, the opamp can't produce high gains and the approximation breaks down. The higher cutoff frequency will be determined by the GBW of the opamp. If the opamp is considered ideal, then this is a high-pass filter.
  • \$\begingroup\$ Thanks for your answer. I ran your simulation and found the similarity. So I might say that C8 in the circuit (your schematic) decreases the passband gain and by doing so results in lowering the cutoff frequency? Have you any idea how the designer comes up with the value for C8? \$\endgroup\$ Oct 15, 2018 at 14:20
  • \$\begingroup\$ From the real transfer function (as given in my answer) you can see how each part influences the cut-off frequency or the gain for high frequencies (set s>>infinite). However, before you have to apply the star-to-triangle transformation. \$\endgroup\$
    – LvW
    Oct 15, 2018 at 14:55
  • \$\begingroup\$ @MarcelvdHeide The Miller theorem does lead to that result. So yes, C8 pushes the cutoff frequency to lower values. Determining the component values can be done in a lot of ways. Using the circuit equations or using simulations. Simultaneously, or progressively. I deliberately compacted the core amplifier in \$A_{DC}\$ because you explicitly worked it out in your question, but it might be easier in this case to start from an equation provided by the other answers to this question. \$\endgroup\$
    – Sven B
    Oct 16, 2018 at 8:05
No, the shown circuit is not a bandpass. It is a first-order highpass (inverting). Here is the transfer function (R2 and C2 are the feedback elements)
$$H(s) = -\frac{R_1C_2s}{1 + s(R_1C_1 + R_2C_2 + R_1C_2)}$$
In the given formula, the three resistors in the feedback path are replaced by R2. This resistor value can be simply found applying the star-to-triangle transformation.
As the result of this transformation you get three new resistors, however two of them play no role: One resistor appears as a load to the ground at the opamp output and the second one appears between the inverting opamp input and ground. Assuming an ideal opamp, both resistors have no influence on the gain.
For this type of circuit, you can apply the fast analytical circuits techniques or FACTs. These techniques will lead you straight to the answer expressed in a low-entropy format. Reduce the excitation to 0 V and determine the time constants involving capacitors \$C_1\$ and \$C_2\$. If you do that correctly, you find out that the \$b_2\$ term is 0: it leaves you with a 1st-order pole. For the zero, determine the high-frequency gain when \$C_1\$ is a short circuit: apply the extra-element theorem (EET) and determine the transfer function in this mode: you have \$H^1\$ and the denominator is equal to \$s\tau_1H^1\$.
What is needed now is to rearrange the expression so that a pole and a flat gain appear. This is what is done in the below Mathcad sheet where you clearly see the pole and the flat part properly defined:
As correctly pointed out by LvW, this is an inverting high-pass filter. For a tutorial on FACTs, have a look at the APEC seminar from 2016.
  • \$\begingroup\$ @Marcel vd Heide, thank you for the small typo correction in the conclusion! \$\endgroup\$ Oct 16, 2018 at 7:23
  • \$\begingroup\$ Thanks for showing your approach of the circuit, things start to make sense now. \$\endgroup\$ Oct 16, 2018 at 7:26
  • \$\begingroup\$ Verbal Kint - the APEC seminar (as referenced by you) is one of the best basic courses for beginners I have seen. \$\endgroup\$
    – LvW
    Oct 16, 2018 at 7:58
  • \$\begingroup\$ @LvW, merci, es ist sehr nett von ihnen! Very kind of you : ) \$\endgroup\$ Oct 16, 2018 at 8:59
  • \$\begingroup\$ ....un plaisir pour moi... \$\endgroup\$
    – LvW
    Oct 16, 2018 at 9:55
