Hi I am unable to upload sketch to Atmel mega1284p using a mcp2221 usb to uart converter IC.
I have a simple code prints "message received" It works to program the Mega1284p using arduino nano as ISP. But not using the MCP2221 over usb. I took a long time and eventually errors out. I tried pressing reset button on ATMega while uploading, I tried swapping TX and RX. I double checked COM port. Please help.
avrdude:
     System wide configuration file is "C:\Users\hhuynh\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.0.1/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 38400
An error occurred while uploading the sketch
This is my setting
This is similar to how my circuit is connected
This is my setup.
This schematic is simular to how mine is setup.
  • \$\begingroup\$ Are you going to tell us the error you received?? \$\endgroup\$
    – Bort
    Oct 15, 2018 at 20:09
  • \$\begingroup\$ avrdude: System wide configuration file is "C:\Users\hhuynh\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.0.1/avrdude.conf" Using Port : COM5 Using Programmer : arduino Overriding Baud Rate : 38400 An error occurred while uploading the sketch \$\endgroup\$
    – user201349
    Oct 16, 2018 at 17:21
Turns out bootloader is erased when programming using arduino as ISP. I need to re flash the bootloader and program through the MCP2221.
    \$\begingroup\$ Yes, good realization. There's probably already the equivalent question here with the same answer but figuring it out for yourself is commendable. Incidentally, this is unavoidable - the ATmega series can only do a partial erase (preserving the bootloader) when manipulating the flash from an internal program. The only erase operation available via ISP is a full-chip erase, so using ISP to replace a program always and unavoidably wipes out the bootloader on these. It is however possible to use ISP to load both a program and a bootloader, either in one operation or without a second erase. \$\endgroup\$ Oct 16, 2018 at 17:50
