16
Yes, that is a haiku.  (EDIT: fixed it... it is now actually a Haiku)
No I'm not smiling.
I'm doing some standard testing; seeing what happens when one of the two power rails gets shorted to GND on a PCB that I designed.  We're talking about a 12 V power rail supplied by a benchtop power supply, with a separate on-board 5 V buck converter that is supplying the other rail on the PCB (which my ATmega328PB is connected to).
The 12 V rail has a bunch of DC barrel jacks on it that will be exposed to end users.  So, naturally I decided to jam a jeweler's screwdriver into one of them to conduct my short circuit test.
Lo an behold, a puff of smoke from my ATmega328PB.
I think that means one of the following things happened:
Schematic Time
Here's the schematic of the connections to the ATmega328PB:
ATmega328PB schematic
Here are all the schematics of things in the design that have a connection to the 12 V rail (the VBAT+ rail) and that control the GND current return paths:
FET Power Control
Analog Front End
And here is a schematic of the barrel jacks and the associated jack detect pins (note that these connect directly to some of the pins of the ATmega328PB with no series resistance):
DC barrel jacks with jack detect pins
The Short Circuit Plan
The plan for dealing with short circuits on the 12 V rail was to simply turn off the LOAD_FET N-channel FET because of one of two logical conditions being met in firmware:
  1. ADC sampling at a rate of 1 Hz would detect the over-current condition and cause the FET_LOAD switch to stop conducting, thus cutting off short circuit current
  2. The voltage supplying the ATmega would go into brown-out condition, and the MCU would reset and initialize the FET_LOAD switch to "off", thus cutting off the short circuit current
The Big Smoke
Here is an oscilloscope probe of what happens to the Vbat+ rail on CH1 (yellow) and the +5 rail on CH2 (blue) when shorting Vbat+ to GND via application of a jeweler's screwdriver to the exposed wires of a cable that is plugged into the barrel jack circuit (I didn't stick the screwdriver into the receptacle) while it is being powered by a bench top supply that is set to 12V @ 5 Amps:
Short circuit | CH1 - Vbat+ | CH2 - +5V
After that happened, the ATmega would simply get very hot whenever I powered up the board, and was effectively acting as a short circuit between its +5V input and signal ground. I desoldered the ATmega with hot air, and tested the FET_LOAD N-channel FET to see if it was fried. Indeed it had failed such that it would no longer turn all the way off or on when a gate voltage was applied to +5 or signal ground, but instead was operating somewhere in the twilight zone between. It was dropping about 2.3 volts while conducting ~200 mA whether it was "on" or "off" when a load was plugged into the barrel jack.
Hunch
Had a hunch that because the FET was damaged that the vector for damage to the ATmega may have been caused by the transmission of a high voltage through the FET drain to its gate and on to the MCU. Did some subsequent tests with lower voltages supplying the 12V rail. Note the first three images are basically the same, but with different peak currents. Once the ATmega shut down (due to collapsed voltage on the Vbat+ rail), the LOAD_GND_ENABLE signal supplied by the MCU (blue, below) in turn goes low, cutting the FET_LOAD switch.
Legend:
CH1 = Voltage across Rshunt (0.005 ohm) CH2 = Voltage at LOAD_GND_ENABLE signal (connected to ATmega)
Vbat+ supplied at 6V:
Vbat+ supplied at 7V:
Vbat+ supplied at 8V:
Vbat+ supplied at 9V:
On that last one, the current never stopped increasing and the LOAD_GND_ENABLE signal did a funky dance, but all in all it would appear that the maximum limits were never breached on the LOAD_GND_ENABLE pin (at least I don't think they were... I only have a 2-channel scope and would have had to have been measuring the +5V rail to know what the voltage on LOAD_GND_ENABLE w.r.t. Vcc).
Next Steps
I only have 1 board left that can be sacrificed, therefore my plan is to:
  1. Use a blank ATmega328PB so that all of its' pins will be defaulted to high impedence with no peripherals configured/initialized. Repeat short circuit test to see if ATmega328PB still goes up in smoke. If it doesn't go poof, then the MCU must have failed because it was sourcing/sinking too much current out of one of its pins configured as an output while it was running firmware in the previous tests.
  2. Test with a ATmega328PB mounted on a breakout board (unfortunately this chip doesn't come in DIP packages) connected to the PCB via flywires. Selectively begin connecting a single flywire at a time, running the test, and seeing which flywire ends up being the one that is responsible for frying the ATmega328PB.
  3. Order a new sample PCB with altered layout such that all traces connecting to the ATmega328PB are connected by solder bridges that can be hand-soldered as I test. This way the short circuit test (and any other testing) can be conducted with the ATmega connected to a limited number of signals at a time, and makes it easy to connect all other external circuitry to these solder bridges to control them independently of the ATmega.
Yes, it really is a question(s)!
And the question(s) is:
  • does anyone see anything here that I don't. Is it obvious? I hope its not obvious...
  • What would your next step be?
  • 5
    \$\begingroup\$ +1 for the haiku and for a really well-done complete detailed question. But unfortunately I do not have the experience/knowledge to even begin to give an answer. \$\endgroup\$ Oct 16, 2018 at 0:37
    \$\begingroup\$ A 1 Second sample rate for short-current is WAY TOO SLOW. Assuming the part at risk is some semiconductor, with active region of thickness 10 microns, that 10 microns having a 1.14 microsecond thermal Tau, you need to detect overcurrent (that short) real fast. \$\endgroup\$ Oct 16, 2018 at 2:21
    \$\begingroup\$ Electric things don’t work after letting the magic smoke out... \$\endgroup\$
    – Solar Mike
    Oct 16, 2018 at 4:01
  • \$\begingroup\$ I wish we saw more questions like this. +1 \$\endgroup\$
    – user98663
    Oct 16, 2018 at 12:07
I think your switch in the LOAD_GND line is probably the guilty party here, combined with the unprotected jack detect lines to the micro (Which I would note are connected to LOAD_GND for any jack where there is NOT a plug inserted.
Consider what happens if you turn off that mosfet (The jack detect lines on any socket without a jack inserted will be connected to the battery voltage via the short circuited load, smoke will ensue), you should at least have some series resistance and a clamp on the jack detect lines (Say 10k or so and a pair of diodes), but really I don't see what the LOAD_GND switch really buys you over a high side switch?
Incidentally, the automotive scene has really nice logic controlled high side switches with built in over current trip and current sensing, well worth a look.
  • \$\begingroup\$ You are absolutely right. Very concise, very right. Thanks be to you sir. \$\endgroup\$ Oct 16, 2018 at 11:33
Which means you put +12V on the unprotected JACK_DETECT line, frying the MCU. See "voltage on any pin [..]" above.
Re-design the circuit that a dead short between VBAT+ and JACKx_DETECT does not allow the voltage on the MCU pin to rise above VCC - e.g. with a resistor and a diode.
Apparently can't comment (yet). But I changed my answer to agree with the above, with following observation.
One item I would attend to is to make sure your FETs are in a well driven state (pullup/pulldown) when the ATMega is in boot/reset state. The pins are normally set to input mode IIRC, which causes the FET gate to float and presents a poor Vgs drive, increasing the channel resistance. If the current flow between the drain and source connections is significant it will overheat/destroy the FET quickly.
