I am trying to calculate the frequency of the internal oscillator, in order to go through the design procedure listed in the datasheet. The problem is that it gives me answers that contradict the 100kHz max f specification. Here is my calculation with the example values in the step-down converter example:
Here is the datasheet I am using:
http://www.ti.com/lit/ds/symlink/mc33063a-q1.pdf
To find the discharge time (tdis), I am using the following values:
C = 470pF (CT on figure 13)
dV = 0.5V (Section 7.4)
Idis = 200mA (Section 7.4)
I then calculate:
Idis = C * dv/dt ----> dt = C * dv/Idis
dt = 470pF * 0.5/200mA = 1ns
since the charge time is 6 times the discharge time, the period T is 7ns, which gives a frequency of approximately 143 MHz. What is happening here?
