What's the best way to quickly connect/disconnect ~22 AWG wires to a test jig pcb? I would like to use a spring loaded connector that can easily release the wire after I'm done testing. Currently have these
banana clip
However they're expensive and don't hold the wire the best. I would like something similar to a fuse clip like this.
fuse clip
Does anyone know of any connectors that can accommodate this?
  • \$\begingroup\$ I assume a standard pin header doesn't work? \$\endgroup\$
    – Hearth
    Commented Oct 17, 2018 at 16:23
4 Answers 4
If you need a good hold for the wire you will need some clamping.
Have you considered speaker connectors?
Or banana binding posts (but they're expensive)
IMO those are overkill for a 22AWG wire. use a header pin and a single piece connector or a test point (lots of version here):
https://www.digikey.com/products/en/test-and-measurement/test-points/616?k=keystone%20test%20point
I personally like the Keystone 5000-5009, they're color coded, you can clip a scope probe to them, or a Pomona style grabber/hook:
https://www.digikey.com/products/en/test-and-measurement/test-clips-grabbers-hooks/620?k=pomona%20clip
Or Screw terminal. This is a Phoenix brand "wire to board" terminal for 12 to 26 AWG wire with 5mm pitch pins enter image description here
How about some lever/pressure activated terminal blocks:
Or even ZIF sockets (not their intended use, I know, but you could probably use it to plug and unplug some wires quickly):
