MOSFET switching
Let's first approximately model MOSFET inductive load switching behaviour, far from a complete study on the topic I'll just recall main points and later on focus on the voltage slope period.
Turn-on phase can be roughly divided into 4 sub-periods here depicted.
Delay time (\$t_0,t_1\$), gate voltage exponentially rise while below threshold voltage, no drain current flowing, the whole load current is now circulating through freewheeling diode, drain is actually shorted to Vcc by this ON status diode.
Current slope (\$t_1,t_2\$), when \$v_\text{GS}\$ crosses threshold \$i_\text{D}\$ begins to rise and starves freewheeling diode, when gate voltage and hence drain current is high enough to get diode current to zero freewheeling diode opens (disregard recovery), from now on \$v_\text{DS}\$ can change.
Voltage slope (\$t_2,t_3\$), now MOSFET has drain current flowing and \$V_\text{DS}\$ can change, it is actually in active region and works like a high gain linear inverting amplifier. Its input (gate) and output (drain) happen to be shorted by \$C_\text{rss}\$ capacitance, this turns the whole stage in an inverting integrator, just the same as the one would build around an operational amplifier, gate voltage reamains constant to what is called Miller plateau.
Gate top-up (\$t_3,t_4\$), when \$v_\text{DS}\$ approaches zero the MOSFET exits active region to enter ohmmic one, it is now fully ON, gate voltage completes its exponential rise from Miller plateau to \$V_\text{GS(on)}\$ as configured in the gate driver.
The turn-off can be roughly modelled simply inverting the above steps, from four to one.
I once more wish to clarify that all the above is just a very basic modelling of actual behaviour and the above graph is also a very simplified approximation and many condition can significantly change the above
Voltage slope
Let's come to the point recalled in the question, the following schematic applies.
On its left hand side we see:
- \$i_\text{D}\$ has now reached the current flowing in the inductor (load) and hence freewheeling diode is open circuit now and has been removed.
- Load inductor itself is modelled has a current generator since switching times are so faster than inductor dynamics not to let any current change happen.
- \$v_\text{GS}\$ is now what is required to let exactly \$i_\text{D}\$ to flow, namely \$v_\text{GS,Miller}=V_\text{GS(Th)}+{i_\text{D}}/{G_\text{f}}\$. It remains constant since \$i_\text{D}\$ is also constant.
- M1 MOSFET works like an inverting amplifier, current source and MOSFET output resistance are its load.
All the above resembles the inverting integrator depicted on the right hand side where rate of change of output voltage can be written as
$$\frac{\text{d}v_\text{DS}}{\text{dt}}=-\frac{1}{C_\text{rss}}i_\text{G}=-\frac{1}{C_\text{rss}}\frac{\text{d}Q}{\text{dt}}$$
where Q is the charge "pumped" into the gate.
Rearranging a little bit we finally get to the relation
$$\frac{\text{d}v_\text{DS}}{\text{d}Q}=-\frac{1}{C_\text{rss}}$$
needed to analize drain voltage slope in the \$v_\text{DS}\$/Q plane.
The answer
Now we have the tools, the graph originally posted shows a steep fall in the left hand side and a flat zero volt line immediately after.
This is basically wrong, drain voltage cannot be stand still as long as gate voltage is at Miller plateau.
What is misleading is expecting \$C_\text{rss}\$ to be constant so to get one of those nice ideal graphs included in more or less all the application notes around.
Instead a quick look to the capacitance to drain voltage diagram
Clarifies that \$C_\text{rss}\$ spans over nearly three decades from 10pF at high voltages up to 4nF at low voltages.
This dramatically changes the \$v_\text{DS}\$ slope, it takes about \$10\,\text{pF}\times 350\,\text{V}=3.5\,\text{nC}\$ to get from 400V to 50V, while around \$2\,\text{nF}\times 20\,\text{V}=40\,\text{nC}\$ can be reckoned to span the last 20V or so.
One should admit that drawing a 1:400 slope difference on that linear-y graph is indeed a challanging task, overdoing a bit that's how it could look like.
I'd end it up confirming such a phenomenon is clearly visible on real switching scope captures once you know where to look.
(Just note this is a turn-off and hence it looks vertically flipped)
