I am trying to measure current from Ignition coil(12V, 4.5A). i used arduino to measure current. And it worked good. And i connected the ACS712 signal pin to NI DAQ 9215. At zero current the output voltage is 2.5v( ACS offset votlage ) which is showing correct in LABVIEW 2017 . But there is no change in voltage when the ignition coil is turned on.
This is thing i got when i measured the signal from current sensor using oscilloscope.
I found the problem for my question. i placed acs-712 to lower side of MOSFET and measured the signal in oscilloscope. and i got the output signal in LABVIEW also.
But the signal is sill noisy in LABVIEW oscillates between 2.5 to 4. I think i should filter the signal.
  • \$\begingroup\$ You have your load and source pins swapped but that shouldn't be a problem since if this has an offset voltage it should be bidirectional. Is the 4.5A continuous, or just a pulse? \$\endgroup\$
    – Hearth
    Oct 18 '18 at 14:29
  • \$\begingroup\$ Spark plug is running at 192 Hz with 20% duty cycle. So it's definitely a pulsed current. \$\endgroup\$
    – HEMARAJ J
    Oct 18 '18 at 14:36
  • \$\begingroup\$ @HEMARAJJ - (a) The ACS712 pin numbering shown on your schematic doesn't match its datasheet. I suspect perhaps you are using some kind of pre-made ACS712 module, not a bare ACS712, and that is misleading the readers. Please give more details about your real hardware. (b) What happens when you view the ACS712 output signal with an oscilloscope instead of the DAQ? (c) Are you saying that you used exactly the same circuit and components, with the ACS712 output connected to an Arduino analog input, and saw the expected varying signal? Or did you make other changes after your Arduino test? \$\endgroup\$
    – SamGibson
    Oct 18 '18 at 15:54
  • \$\begingroup\$ @SamGibson This is hardware i am using (components101.com/sensors/acs712-current-sensor-module). Not viewed the signal in oscilloscope, Made some changes in the above circuit i powered the ACS712 from my arduino. I am facing some problem if connect the acs712 to above circuit ( Connected using 7805 ) \$\endgroup\$
    – HEMARAJ J
    Oct 18 '18 at 18:05
  • \$\begingroup\$ @HEMARAJJ - (a) Thanks, so my guess was right and the schematic is incomplete as it doesn't explain that is is an ACS712 module, which has extra components on it. Also, the PCB layout on that website doesn't even match their own photos, so can we trust the accuracy of anything they say? (b) So please view that signal with an oscilloscope and update the question with the result (e.g. scope trace screenshots etc.). (c) I didn't understand the next part of your reply. I can't help further unless your replies are clear :-( \$\endgroup\$
    – SamGibson
    Oct 18 '18 at 19:17
