TL;DR: I want to know if there is anything, That on which when a radio frequency falls, and it turns on an LED. Basically an on off switch but controlled when radio waves hit it.
What I hope to achieve is that, I want to have a remote of sorts, And when I press a button, the LED turns on. Without having line of sight.
Why? Because my dog and I play fetch at night, (Don't ask why I have many reasons to. If I could at day I would've but can't.) and I almost always lose the ball every night into the bushes and it's too scary to look for it. I have lost many balls and it's become annoying and expensive to lose balls every night. (I'm a student).
What I have in mind is the idea that I could press a button and it transmits radio frequency and when it hits the ball the LED turns on so I can see it.
I know an Arduino could be used to do it - I found blinking codes for it too but I can't fit it into a ball and even if I did my dog would crush it in his mouth. (And also I don't know much about coding so I'd best avoid it.) So ideally I am looking for something really small and simple that would be inside the ball so if even he bites it there's a good chance he won't crush it.
What I want to know is, is there anything that is available like what I described? A switch that, when RF falls on it, lets current pass through it like a switch allowing the LED to turn on bright so I can find it? Does anything like that even exist? I can find voice activated clap/sound/light/heat/temperature/IR everything activated switches but not this. Enlighten me.
    \$\begingroup\$ FYI: Product recommendations are off-topic here. Ask about design. \$\endgroup\$
    – Bort
    Oct 18 '18 at 19:38
  • \$\begingroup\$ @Bort Im so sorry this is my first post here, i did see it in the rules but never thought i had asked for that, I am really very sorry. Can i edit it off? \$\endgroup\$
    – Shah
    Oct 18 '18 at 20:27
  • \$\begingroup\$ You can either edit your question to be about design, or delete it all together. \$\endgroup\$
    – Bort
    Oct 18 '18 at 20:33
  • \$\begingroup\$ is it okay now @Bort \$\endgroup\$
    – Shah
    Oct 18 '18 at 20:38
    \$\begingroup\$ if it is scary to go into the bushes, then how is it less scary if there is a lit LED in the bushes? \$\endgroup\$
    – jsotola
    Oct 18 '18 at 20:42
Why not have the led on all the time? You can do that with a coin battery and an LED and the total cost is not much. Here is a link to an article on how to make what you need. You could leave the magnet off because it will be inside the ball.
LED Throwie
  • \$\begingroup\$ Never thought about that ... Ill do that if i cant find a solution to my problem. But Lets wait if can get a solution to that Because dont you agree that would look very cool and i might learn a thing or two about electronics along the way, Thanks for the idea btw! \$\endgroup\$
    – Shah
    Oct 18 '18 at 20:22
  • \$\begingroup\$ you could build a low power flasher so that the battery life is increased ..... google low power flashing led \$\endgroup\$
    – jsotola
    Oct 18 '18 at 20:47
  • \$\begingroup\$ There are already flashing light dog fetch balls on the market. The main issue is standing up to chewing. \$\endgroup\$ Oct 18 '18 at 21:21
