I am planning to use an external DAC + amplifier combo to output mono sound from my microcontoller. The ouput from the amplifier would be connected to a single speaker
DAC : PCM5102
AMPLIFIER : PAM8019
The sound data from my mcu is MONO format and both these chips support 2 channels.The I2S data will be mono.
My question is how do I just use the single channel on them? What do I do with the OUTL pin (on PCM5102) and LIN, LOUT-P and LOUT-P pins(n PAM8019)? Do I simply connect them to ground?
PCM5102
PAM8019
I've never worked with audio before so all this is new to me.
Thanks for the help!
  • \$\begingroup\$ 1: Don't hook outputs to outputs, unless they're specifically designed for it. 2: Ground is an output. \$\endgroup\$ – TimWescott Oct 19 '18 at 16:39
  • \$\begingroup\$ I would connect the left channel between the two chips as normal (I assume there's a recommended circuit in a datasheet someplace). Then I would leave the left channel output pins of the PAM8019 open. \$\endgroup\$ – TimWescott Oct 19 '18 at 16:40
  • \$\begingroup\$ I assume you meant leaving the right channel output of PAM8019 open. But would that not induce noise? \$\endgroup\$ – Ankit Oct 19 '18 at 18:54
