I'm trying to get a PIC12F1822 to run at 32 MHz. Here are the relevant bits of code:
__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
__CONFIG _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_19 & _LVP_OFF
MOVLW b'11110000' ; 32MHz HFINTOSC
BANKSEL OSCCON
MOVWF OSCCON
BANKSEL OSCSTAT
btfss OSCSTAT, HFIOFR ; Is internal oscillator running?
goto $-1
btfss OSCSTAT, HFIOFL ; Is internal oscillator locked?
goto $-1
BANKSEL TRISA
CLRF TRISA
BANKSEL PORTA
ON
BSF PORTA,2 ; 1 cycle
GOTO OFF ; 2 cycles
OFF
BCF PORTA,2 ; 1 cycle
GOTO ON ; 2 cycles
I'm getting a 1.33MHz square wave from PORTA,2, meaning that the clock is running at 8MHz... The PLL is definitely working though, as if I switch it off, the freqency drops to 333KHz (2MHz)
According to the debugger (PicKit3), OSCCON is getting the correct value.
The chip is running at 5 V.
Any ideas?
