I have a European power strip Schuko socket with switch (it looks like this
and this).
Mine has 3 Schuko sockets. I cannot open the power strip because it has round head carriage bolts with fastner-like threads(what's the name of their thread?) instead of screws.
Its Shucko plug (CEE 7/7 plug) is connected to a Shucko socket (CEE 7/3 socket) in the wall that has only one live wire (I've checked), which is the normal way things are here, and I'm pretty sure the ground is properly connected. Someone mentioned that's possible both wires can be live but this is not the case for me, that's why I mentioned this info.
The power strip and its light switch seem to work as intended, except when I connect my newly defunct washing machine (which stopped working during the last rinse cycle, for reasons yet to be determined).
The machine acts as if it's not receiving any power, however the power strip's light switch remains lit regardless of the power strip's switch's position (on or off) when (and only when) this washing machine's Schuko plug (CEE 7/7 plug) is connected to this power strip.
What and why could cause the power strip's light switch to light up even when the switch is in the off position ?
Connecting other plugs into the power strip do not cause the switch light to light up while in the off position! So there must be something that the defunct washing machine "does" internally that's causing this.
I've tried rotating the Schuko plug of the washing machine but the switch light still stays lit while in the off position.
However, I just tried rotating the Schuko plug of the power strip itself and it worked: the switch light is no longer lit while in the off position. Frankly I don't remember if the light was ever on while the washing machine was previously working(as in, not defunct) and the power strip's switch was in the off position. I do however remember the power strip's switch light being off when it was turned off, while the washing machine wasn't defunct, without having changed the power strip's Schuko plug wall position! This leads me to believe that somehow the washing machine defunctness is the cause of the power strip's switch light being lit even while in the off position, but I've no idea why would this happen!
UPDATE:
I was able to take the following picture from inside the washing machine:
The white pipe-looking thing is the power cable.
EDIT: To get a clearer idea of how the above actually looks like, here are two pictures from somewhere else:
Apparently it's called a "Surge filter". So I can only infer that the way it broke makes the off position of the power strip switch's lamp light up.
UPDATE
I pulled out the surge filter from the washing machine, here's a better picture of the meltage:
(I can't upload images for some reason(imgur won't do anything), so here's the link)
https://user-images.githubusercontent.com/40925413/47820832-fdd41880-dd5e-11e8-8171-9fc270164ac6.jpg
I've also broken into the power strip (because it wasn't working too! took me a while to realize because I didn't try to use it until now). So one of the contacts inside the red switch was melted into the plastic, no doubt a side effect of the above:
https://user-images.githubusercontent.com/40925413/47820826-fa409180-dd5e-11e8-9eee-278c014d31d9.jpg
