How do you find out what voltage is being used on a data bus for the high signal?
On a small electronics I guess you can assume it will be 3.3v or 5v but what about other circuits, say in a car or on the side of a TV or some old random electrical equipment without knowing the spec of a port.
If I wanted to connect say a logic analyser to some digital bus, not knowing anything about it, how would I first find out the voltage to make sure I don't blow up my logic analyser and then, once I know what the peek voltage will be, so I'll not blow up my logic analyser by connecting it, how do I bring the voltage down to the right level (Some sort of Attenuator?) so that I can see the data on the bus?
    \$\begingroup\$ Oscilloscope, datasheet, circuit diagram, user and service manual. \$\endgroup\$ – Anonymous Oct 22 '18 at 11:03
If you have a data bus then you'll probably have a clock signal and that clock signal will be about 50% duty cycle. So, using a DC voltmeter you could measure the clock and ascertain the average DC voltage then multiply that by 2 to get the logic 1 voltage (approximately).
If you don't have a clock signal then try measuring a data signal with the voltmeter and usually you will see about 50% of the logic voltage if the data signal is actively sending data.
  • \$\begingroup\$ Thanks Andy, that answers the first part of the question, do you have any suggestions for how to bring the logic voltage down to a level so that I would be able to attache a low voltage logic analyser to it? \$\endgroup\$ – Mark Fidell Oct 23 '18 at 10:11
  • \$\begingroup\$ @MarkFidell you may not need to attenuate and if you do you may get-away with simple series resistors of 1 kohm that act as current limiters. If your logic analyser has a data sheet please post a link. \$\endgroup\$ – Andy aka Oct 23 '18 at 11:36
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
