I'm looking at this paper which proposes an energy function for a 3-bus power system example. I'm trying to replicate the results in the paper but am uncertain about the D parameters in Sec III. In particular, the authors verify that with a certain A matrix adjusting the gradient dynamics, the model has a stable equilibrium, but I'm confused about the D parameters in this matrix.
Here is the relevant section:enter image description here enter image description here
EDIT1: it looks like the D terms are some sort of rotor damping.
EDIT2 (follow up question): I'm having trouble tying out the dimensions of the A3bus matrix to the Abus matrix. Specifically, the dimensions of Mg seem off. It appears that the g means both slack and generator node, but then I don't see how to fit A3bus into the Abus structure. Any advice?
EDIT3: this paper helps somewhat but is still a bit unclear on the interpretation of the Pi matrices.
Thanks!
    \$\begingroup\$ What page specifically were you looking at? \$\endgroup\$ – W5VO Oct 22 '18 at 22:37
  • \$\begingroup\$ Sorry, just realized I uploaded a different but related link. Let me extract the pages of the paper I'm referring to \$\endgroup\$ – rrrrr Oct 22 '18 at 22:45
Stub of an answer right now, but the D parameters refer to machine damping values in the classical swing equations. The epsilon parameter is a singular perturbation of an algebraic constraint related to the reactive power flow.
