I bought a used signal generator today. I want to check if it works with no problem but I don't have access to an oscilloscope right now. I have a multimeter that can measure dc and ac voltage and also frequency. When I connect it to the generator it shows the exact frequency that the generator is set to, so there's no problem there. I also checked the DC-offset feature with DC voltage measurement, no problem there as well.
But when I try to measure the ac amplitude I get 300mv rms when the generator is set to 20v peak to peak and no logical relation to the value shown on the generator in lower amplitudes. I checked the multimeter with 220vac and there was no problem with it. I also checked it with a dc power supply I have and there was no problem with the multimeter there neither. I connected the output of the generator to a simple half-wave rectifier circuit I made with a resistor, a capacitor and a diode and measured the output dc voltage with the multimeter and it shows ((Vp-p)/ 2 )* 0.68 for the sine wave which is around 30% lower than what I expect. the diode on voltage is 0.55 R=1k and C=470uF. So there is actually a somehow valid output amplitude on the generator but I can't see it directly with my multimeter.
I also tried lowering the frequency but I still couldn't measure the ac voltage directly with the multimeter. It seems that both the generator and the multimeter are working fine but somehow I can't measure the ac output rms value of the generator with the multimeter. What do you think the problem is here?
I have PNP and NPN transistors and diodes if you want to suggest another test with a simple circuit. The generator is an MFG-8306 from MCH Instruments and the multimeter is a Victor VC97.
  • \$\begingroup\$ Ah I think you added that just as I was typing, what was the (sine wave?) frequency you've tried? \$\endgroup\$ – isdi Oct 22 '18 at 23:59
  • \$\begingroup\$ I tried 50Hz to 5MHz but saw no change on the value shown on the multimeter. \$\endgroup\$ – sadegh satari Oct 23 '18 at 0:08
  • \$\begingroup\$ The Victor shows 1KHz sine as max for true RMS values. I'm going to assume it autoranges. \$\endgroup\$ – isdi Oct 23 '18 at 0:08
  • \$\begingroup\$ Do any of the other amplitude output range settings give reasonable values (if I read what you said you've already tried it at lower frequencies)? I can't find a manual on the generator, so more troubleshooting for me would be stabs in the dark. BTW don't do a sweep, it tends to mess with the integration function on some DMMs as the frequency response rolls off. \$\endgroup\$ – isdi Oct 23 '18 at 0:13
  • \$\begingroup\$ I have the manual, What information do you need? I can add a picture of the relevant page. \$\endgroup\$ – sadegh satari Oct 23 '18 at 0:22
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
